S Won't start :(
Old Jun 11, 2018 | 09:28 PM
Tito TW's Avatar
s550
S Won't start :(
Hi Guys, hope that I can find some ideas before I call the tow truck.
2009 S550 104k Miles
Issue: Car was running fine, turned off in the driveway and that was it. Car won't turn over at all. you can press the start , nothing, you can try with the key nothing , no click, no attempt to start, nothing, I replaced the battery because I found the old one low in voltage, nothing, I have checked the start fuse, it looks good, checked the two start relays looks OK, changed the key batteries nothing, the only thing that I have notice is that you can lock the car but the mirrors won't fold in as usual, not sure if that's related to anything, last year, I replaced the small battery and all the info appears on the display as normal.
Anything I should look into?
Old Jun 11, 2018 | 10:19 PM
Donnymac's Avatar
63 Falcon vert
From experience with other cars not starting as you describe, you might check the nenegative ground connection (not the terminal). I have no clue where the cable attaches or how but I know what happens if that connection is not secure or clean. And it's probably hard to get to.
Good luck.
Old Jun 11, 2018 | 11:48 PM
ItalianJoe1's Avatar
2003 CL 600
Check power to the starter first. Common failure at this age/mileage, and presents like you say, just goes from working to dead.
Old Jun 12, 2018 | 09:27 AM
lionsfan54's Avatar
Mercedes Benz S600
+1 for the starter. Had a Honda do the exact same thing. It ended up being the starter, it just up and died while I was pumping the gas and went to start it again.
Old Jun 12, 2018 | 08:04 PM
belanger's Avatar
2012 S550
That's when you bust out the trusty hammer and give the starter a good solid whack!
Well, maybe not on a Benz starter, but I've gotten other cars moving with that trick...
-MB
