Replacement Tires - higher aspect ratio
Old Jul 29, 2018 | 07:08 AM
JAMJR's Avatar
2012 S 350 Diesel
I have a 2012 S350 Blu-Tec with Continental 255/40 R19 100V tires and I hate the ride of these low profile tires, Is it possible to go to a 45 or 50 aspect tire with this vehicle without causing any other problems ??
Old Jul 29, 2018 | 04:00 PM
dlafever's Avatar
'15 S550, '10 E350 P1/P2, '02 ML320
I'd think you would want to go to 18" rims if you're going to increase the aspect ratio, otherwise rubbing and shredding.
Old Jul 30, 2018 | 03:46 PM
w2830's Avatar
2013 S550(W221)
I’d be more worried about incorrect speed reading.
Old Jul 30, 2018 | 08:45 PM
SilberGrau57's Avatar
2004 W240 Maybach 57
You would want to maintain the same sidewall height to maintain overall tire size. The formula is 255 x 40% = 102 mm for your current tire. If you went with a 45 series tire, you would need to find a 225/45R19 tire (225 x 45% = 101.25 mm) or a 50-series tire would need to be 205/50R19 (205 x 50% = 102.5 mm). I'm not saying these tire sizes exist, only that they would give the same overall tire height as your current, albeit with a narrower tread width. The 225 tire is 30 mm narrower than the 255, and a 205 tire is 50 mm narrower than 255.
