2007 S550 Battery issues?
Old Aug 13, 2018 | 04:26 PM
Avalon786's Avatar
2007 S550 RWD Barolo Red
Unhappy 2007 S550 Battery issues?
Hi.
I have a 2007 S550, ~80k miles. I rotate cars I drive, so it sat for ~14 days. I go to drive it. Fob does nothing, door handles don't work. Used the key to get in, push start fires it up. But the clock resets and it acts like a dead battery would I assume (but am not sure). All the screens seem to reset at start up but then it's normal. Except the massage seats don't work. Nav took a min to load. Seems like the car did a "reboot" so to speak. I drive to work ~30mins, turn it off and same, the whole car electronically speaking is dead. It starts right up and clock does the reset again and all...
Any idea what this is? Secondary battery maybe?
I don't have voltmeter to check. Last time it was serviced like 2 months ago battery readout was good.
Old Aug 13, 2018 | 04:40 PM
Jaap's Avatar
2006 W221 S500L M273
Yeah secondary battery.
Charge it fully and have it tested.
I can't let the car sit for a week or the sec battery goes to 11V or so.
Old Aug 13, 2018 | 04:54 PM
Avalon786's Avatar
Arrow
Ok, that's what I was thinking. How do you charge up the secondary battery?
Old Aug 14, 2018 | 06:23 AM
Jaap's Avatar
It's in the trunk (between the trunk and the passenger compartment).
Remove the panel fom the trunk starting in the upper left corner.
Then you'll see the sec battery.
Old Aug 14, 2018 | 10:48 AM
EasyPhil's Avatar
2007 S550 4Matic 2013 S550 Base
Originally Posted by Avalon786
Hi.
You can get the battery tested but the odds are it will need to be replaced, I would just replace it which isn't difficult. The back of the trunk you can pull back (be careful not to break it when you pull) which exposes the battery. Simply unbolt the cables from the terminals, pull the battery, insert the new one and reconnect the cables. I had the same issue as you, though my battery had a little more "juice" than yours.
Old Aug 15, 2018 | 02:17 AM
Avalon786's Avatar
Stopped by MBZ dealer. Indeed it turned out the car was still on the stock "chassis" battery. Not a bad run. It was from 2006 and completely dead, like at zero. They also tested the "starter" battery and that was weak, that one dated from 2009. My car needed an oil change, had them just take care of it. In my current situation I just don't have time right now to tinker. P&L was like ~$450 for the trunk battery, ~$250 for the starter one, if anyone is curious.
Positive note, my rear sunshade that was inop now works! And the car is much happier. It was starting to do odd stuff with the drained batteries.
You have already rated this thread Rating: Thread Rating: 1 votes, 4.00 average.
