P0366 & P0367 Codes - Oil in Sensors
So, 2013 S550 with 78,000 miles, yellow check engine light comes on and is throwing p0366 and p0367 codes for camshaft and crankshaft sensors. Dealer diagnosis problem and find oil has migrated up through the wire into the sensor and is causing the code. Claiming its a rare problem that effects only 1% of the cars and the "plan b" repair is to replace the sensors and cables or whatever and apply a type of sealant that will insulate the sensor from future oil intrusion. $1,300 bucks. Plan A is an ugly repair, says he, that could cost 9 grand, but they are confident that plan b will fix the problem and shouldn't happen again.
Anyone ever go through anything like this? I'm not a DIY guy, but I have a relationship with another mechanic and if simple enough can have him do it (assuming significant savings). Half tempted to not even bother with the repair until the car starts acting hinkey. Right now performance isn't altered...just stupid yellow light.
Thoughts?
Thoughts?
Hey man I hate bumping old threads but what ended up happening with this? Did you end up waiting or getting the fix? I have a diagnosis tomorrow on my ‘13 scheduled.
Thoughts?
Thoughts?
Since I had 4 sensors I was able to get 3 cleaned that work when rotating from one spot to another. One sensor kept on failing no matter where I placed it or how much I cleaned ( bad sensor and it was one of the newly bought ones). I also noticed if the sensor is not tightened right it will not function. Buy be careful not to tighten too much. Good luck to all
