Changing Unit Settings from Fahrenheit to Celsius in Cluster
I did. You can easily change the temperature setting from C to F and vice versa.
I hope it helps,
Pitek
P.S. I do not know if it is going to work for your 2019 W213 E Class. I could check it for you during this weekend (Sunday) or you will have to email or call them sooner in that regard.
When I purchased the scanner on-line it did not have that option available. It was my sole idea to have it added. I worked very closely with their fantastic team of software programmers coding in Poland I was honoured to be the first user to successfully test it. It was added on my request to my S class (all years). It took a short while but it was worth it. It works like a charm now! And everyone who bought their module can enjoy it. I know, I am.
F to C or MPH to KPH should always have been a user selectable feature (I know they added the ability to change speed display in later car's - on later hardware) but both units should have been in all of them the day they built the first one
Exactly! Absolutely! I agree with you 100%. You said "another crazy way to build cars." I would add to it "and make (aka steal) money." A stealer requires at least 1/2 hour to make that change through their DAS with a total cost well over 100 Canadian dollars plus 13% HST on the top of it.
Thank you,
Pitek
The scanner covers your "beauty." However, I will have to check manually on my scanner if the conversion can work for your model. I will be able to check it for you over the weekend - probably Sunday.
Thanks,
Pitek
I tried. However, I am getting this error message:
dbrad32 has chosen not to receive private messages or may not be allowed to receive private messages. Therefore you may not send your message to him/her.
Change your settings.
Thanks,
Pitek
I had it finally and permanently resolved and corrected using a scanner purchased in Poland.
The programmers added the feature in their scanning software to make it easy to toggle between Fahrenheit (F) and Celsius (C) degrees, and vice versa.
Again, this change is not possible through any of the car settings (e.g. Comand).
Thank you,
Pitek
best
I can't send you a PM. Instead, I emailed you the requested information to your private email.
Have fun!
Pitek
