Warning beep on accel from stop
Old Dec 28, 2018 | 09:41 PM
justinmorrison's Avatar
2009 S550
This started about a month ago and I bet someone knows the story. Once in a while (once a day maybe) my car will beep (the same beep as when there’s a warning on screen like a bulb out or something), but no warning lights or other visual indicators will be present. It usually happens when accelerating from a stop, and more often when it’s a hard acceleration. After the one beep, nothing else to indicate a problem. Any ideas what the cause may be?
Old Jan 2, 2019 | 10:35 PM
Polar Bear's Avatar
W221 S600, W220 S55 AMG Kompressor, W124 300E, W140 S320, W210 E3204M W164 ML320 Bluetec
There is a note in TIPS that mention something very similar - a single unexpected beep when the ignition is turned on. A IC software update is the fix. May see if your dealer can do this. What year is the car?
Old Jan 13, 2019 | 07:49 PM
2009 S550
It’s an 09. Doesn’t happen on ignition, only when accelerating from a stop, and only once per day at most.
