Question on amplifier compatibility
Old Jan 13, 2019 | 04:22 AM
07CL550Benz's Avatar
2007 CL550
Hey, wondering if anyone knows if an amp out of a S550 or even newer year CL550 would work for my 2007 CL550. Mine is blown so I've got no music whatsoever. The dealership told me the part number for my car is 221-870-50-89-80. I'm thinking the likelihood of finding an amp for sale from a S550 is a lot more likely but I'm not sure of their part number. Any help is appreciated.
Old Jan 13, 2019 | 05:52 AM
konigstiger's Avatar
'71 Pinto
Add 80 to part # for MB remanufactued, shop both (normal, +80) for each...
Old Jan 13, 2019 | 06:07 AM
2007 CL550
Thank you! Do you know if these are the same part numbers for an S550? And if so what year range?
Old Jan 13, 2019 | 09:18 AM
'71 Pinto
Yes, as indicated by 221 in part #: 2007-2013 CL600/CL63/CL65/CL550/S600/S63/S65/S550 with 221-870-50-89 being current.
Old Jan 13, 2019 | 07:05 PM
clb00196's Avatar
2001 mercedes e55 amg
If you contact this place below they will repair your amp and give you a one year warranty. The reason the amps all die is cause the fan inside of them actually sucks in the brake dust from the wheel well and eventually builds up burning out the amp. I bought an used amp on ebay and this company repaired it. I dealt with Thomas Mitchell at the shop. Its like 400-500 to repair. If the amp is re-manufactured and the fan isn't corrected to push the air out instead of into the amp it will die over time. Tom, told me its a build defect in all the amps. My car when was delivered had the amp stolen by either the transport or the shady dealership in Chicago where I bought it from.
https://www.beckerautosound.com/
Old Jan 13, 2019 | 10:26 PM
2007 CL550
Thank you for that information, very helpful. Sorry to hear about your amp that is terrible, hope you got compensated somehow.
Old Jan 13, 2019 | 10:38 PM
clb00196's Avatar
Never got any compensation but it’s all good.
Old Aug 4, 2020 | 11:02 PM
Elbalt's Avatar
S550
[QUOTE=clb00196;7653384]If you contact this place below they will repair your amp and give you a one year warranty. The reason the amps all die is cause the fan inside of them actually sucks in the brake dust from the wheel well and eventually builds up burning out the amp. I bought an used amp on ebay and this company repaired it. I dealt with Thomas Mitchell at the shop. Its like 400-500 to repair. If the amp is re-manufactured and the fan isn't corrected to push the air out instead of into the amp it will die over time. Tom, told me its a build defect in all the amps. My car when was delivered had the amp stolen by either the transport or the shady dealership in Chicago where I bought it from.
https://www.beckerautosound.com/[/QUOTE
l called these guys yesterday. They’re in New Jersey. They said $700 to fix and one year warranty or $700 for a rebuilt one with your old one as core. A little too pricey.
Old Aug 5, 2020 | 11:31 AM
'71 Pinto
Current part # is 2218707789 most times plug & play but note you may need STAR (MB diagnostics) to transfer data and read fault memory per attachment (N93/1).
MB only offers this part remanufactured.
Ebay offers 7789 @ $699 or best offer + shipping same pricing as Becker however, Becker offers one year warranty and should handle data (no affiliation with either): https://www.ebay.com/itm/07-09-MERCE...AAAOSwr9Bef1xj
Alternative to find cheapest price, search compatible part #s listed here:
File Type: pdf
File Type: pdf
Old Aug 5, 2020 | 12:02 PM
DaleB's Avatar
Veteran: Army
2007 S600
A little cheaper from M-B of Laredo... great people to deal with.
https://www.mbpartsource.com/oem-par...r-221870778980
Old Aug 10, 2020 | 02:12 PM
Elbalt's Avatar
S550
hello all, please I need help. How do I know if my Amy is the one acting up?? Command unit radio station is blank and no audio. Navigation map works but no audio. When I go to the trunk, I removed all the wire connections and I noticed the following:
1. when I removed the fiber optic connector, I notice the red light blinked three times from the amplifier. ( so that means it’s getting the fiber optic signal? )
2. at the wire plug connector, I noticed few rust , I tried cleaning them out with no luck.
3. the fan behind the amp is not spinning , ( I’m assuming power is not getting to the amp? Is the far supposed to be spinning while the car is on?
also, I’ve used the fiber optic loop by pass on the voice command and the Siri’s satellite box. Still no audio. I planned to send the amp to the Mercedes Benz Specialist later today but I just want to make sure that the amp is the real issue. Please, help. Let me know what you guys think. Please , see below pics .
The radio station screen is blank and no audio .
Is the fan behind suppose to be spinning while the car is on ? In my case, the fan is not spinning while everything is connected. But getting the red blinking lights.
Old Aug 11, 2020 | 08:55 AM
BOTUS's Avatar
S500
Originally Posted by Elbalt
. How do I know if my Amp is the one acting up?? Command unit radio station is blank and no audio. Navigation map works but no audio.
that's it... those 2 faults all you need to know... its dead. you need a new one ( just like every other owner did) both of those two things are produced by the amp
Old Aug 11, 2020 | 09:21 AM
Elbalt's Avatar
S550
thank you!!
Old Aug 11, 2020 | 12:09 PM
BOTUS's Avatar
S500
the big amp is crazy money.
You have a guy says he can fix them in USA (regularly offers the service, hunt down some posts). Not seen anyone with success do this in Europe. I don't think its impossible... just no one shared what to fix. Probably a reflow issue on a chipset. Its becoming the standard circuit board failure. Perfect design to fail idea... as they can claim it wasn't engineered to die on purpose "somehow yours must have overheated". Like you can explain / prove exactly how you looked after something every day.... when you've never seen or knew it existed for 7 years before it broke
Old Aug 11, 2020 | 01:15 PM
Elbalt's Avatar
S550
[QUOTE=BOTUS;8130098]the big amp is crazy money.
You have a guy says he can fix them in USA (regularly offers the service, hunt down some posts). Not seen anyone with success do this in Europe. I don't think its impossible... just no one shared what to fix. Probably a reflow issue on a chipset. Its becoming the standard circuit board failure. Perfect design to fail idea... as they can claim it wasn't engineered to die on purpose "somehow yours must have overheated". Like you can explain / prove exactly how you looked after something every day.... when you've never seen or knew it existed for 7 years before it broke[/QUOTE
i agree with you 100 percent . Also, someone referred me to a guy in Florida, )Mercedes Benz Specialist), they also advertised on EBay as well that they do repairs the amps. They have lots of good reviews on eBay on their page regarding fixing the amps from previous customers. I spoke to one of the guys in Florida’s and asked me to mail it to him and I should get it back in 5 days. Also, they will let me know if it can’t be fixed . He sounded very confident and also have 6 months warranty. I will update this posted after o get it back from him. He’s charging $275.
Old Aug 11, 2020 | 01:55 PM
DaleB's Avatar
Veteran: Army
2007 S600
That's a bargain.
Old Aug 11, 2020 | 02:11 PM
COUPCONNOISSEUR's Avatar
2010 CL550
Originally Posted by DaleB
That's a bargain.
paid $650 for amp repair at Becker autosound. So definitely sounds like a good price..although I’m satisfied with my amp and the time it took them to repair it.
Old Dec 17, 2020 | 03:25 PM
vervuurt's Avatar
CL550 AMG package
[QUOTE=Elbalt;8130148]
Do you have his contact information?
Old Dec 18, 2020 | 06:15 AM
BOTUS's Avatar
S500
no, but the amp dying happens to every single owner of a 221, so check for that sort of post inside the last year. he used to pop up and offer on many threads about amps
Old Dec 18, 2020 | 06:24 AM
vervuurt's Avatar
CL550 AMG package
Called him yesterday, about to ship him ny Amp, today
Old Mar 27, 2021 | 03:40 PM
Amy Miller's Avatar
2007 GL450
[QUOTE=vervuurt;8226974]
did you end up finding his contact information?
Old Jul 29, 2021 | 04:11 PM
MBs550Andy's Avatar
S550
Can u give me the guy's contact information or how 2 find him on Ebay I need this amp
Old Jul 29, 2021 | 04:17 PM
MBs550Andy's Avatar
S550
how do I contact or find him on Ebay
Old Jul 31, 2021 | 11:20 PM
vervuurt's Avatar
CL550 AMG package
[QUOTE=MBs550Andy;8385134]
http://mandbspecialist.com/
Old Apr 4, 2022 | 06:17 PM
Brexon's Avatar
2007 CL 550
Hi, I am looking to buy the radio amp for my CL550.
Anyone?
