2008 S550 Fuel Pressure Drop Question
Old Jan 20, 2019 | 04:58 PM
Polo35m's Avatar
2008 S550
Hey guys I've got a high mileage 08 S550 that has developed a starting problem when cold. The car will not start until after three or four attempts. I put a screw-on type pressure gauge on the fuel rail to monitor the pressure and sure enough overnight the pressure drops to zero. As soon as you press the start button, it immediately shoots up to 55, but doesn't always start until three or four attempts. Then it is fine for the rest of the day. So my question is, does the fuel pump itself have a check which maintains pressure or is there a check valve somewhere in line that I should be looking for? I'm considering just replacing the fuel pump on Principle as the car does have 160,000 miles. Clearly I don't think this is a problem with the pump not working or the relay for the ECM or the DAM as the pump is kicking on when the start button is pushed. Again, the problem seems to be it is losing pressure overnight. Any help greatly appreciated.
Old Jan 20, 2019 | 07:45 PM
Polo35m's Avatar
2008 S550
Well unfortunately I'm not subscribed to Wis but I think I'm just going to replace the fuel pump...it's only $45. Another MBZ site indicated that the fuel pump itself does have an internal check valve so that sounds like a pretty inexpensive easy try. By the way what does FUYAA stand for?
Old Jan 20, 2019 | 07:48 PM
tusabes's Avatar
Mercedes
don’t forget to change the fuel filter too , it has a check valve and might be the problem
Old Jan 20, 2019 | 07:55 PM
Polo35m's Avatar
2008 S550
Thank you. Yes, you are correct and I replaced that last year. It was actually clean as new but it had the tiny micro crack in the top resulting in fuel smell that is common with these cars. If the fuel pump doesn't do it I'll change that next but the fuel pump is just so easy I think it's stupid not to.
Old Apr 17, 2026 | 11:37 AM
moazzemzaidi's Avatar
S500 W221 | 55' Bel Air | 60' Bug
Were you able to solve the falling fuel pressure by replacing your pump?
Old Apr 19, 2026 | 09:14 PM
Polo35m's Avatar
2008 S550
Wow this is an old thread but it's a matter of fact yes replacing the fuel pump solved the problem apparently there is an internal check inside.... it was very inexpensive and as I recall I just bought a cheap one off Amazon I no longer have the car but it did fix the problem
