Chain/ Balance shaft gear AGAIN?
Tensioner is still in. I have just removed front cover, and one pulse wheel. (btw what is the size of torx on the other side of cam?)
Now, when I looked at it again, one mark seems one teeth off. Take a look at the pictures.
Yes, check engine was getting back immediately after erasing fault memory. At first while driving it was on and off for some time, but later it was constantly on. And sometimes I had long crank before start.
These are the only screenshots I have on my computer but I will get some that better show stretched chain and worn balance shaft faults.
In this screenshot I have marked of the same position twice on the cam sensor signal to indicate 720 degrees of crank rotation. The vertical lines in between are measuring the difference between left and right side camshafts. The bottom right value with red line shows 2.146 degrees difference side to side. More than 4 degrees difference will set a code. These screen shots are from a vehicle that suffered short term oil starvation which can result in damage to the cam adjusters. We hooked this up to get an idea if any damage had been done. Vehicles we have measured with new chain and balance shaft will typically be between 0.5-1.8 degrees difference. This is not bad and no repairs made.
This shows the exhaust cam difference side to side of 2.77 degrees. a little on the higher side compared to new but not alarming for 110k miles.
This is the setup shot to take the measurements. Ever since using this method of proper diagnosis I dont have to remove any components from the car. No wasting time or money throwing parts at the car and crossing fingers, no removing cam sensors to check the plates, no pulling covers, keep your hands clean and diagnose it properly.
As far as the ECU I have my theories that I want to get some screenshots tomorrow that will help better explain.
Very infomative, thank a lot @knowbenz Pico 4 chanel scope will be in my shopping list.
https://www.ebay.com/itm/Mac-Tools-4...kAAOSwo49d4W5U
Now I'm thinking, that it should be a chain, or a sprocket, because it doesn't look like anything else.
Evaluating, that sprocket has been changed, and it shouldn't fail second time, (as it was manufacturing problem at the beginning) I will change a chain.
I have ordered from Febi, will not go for OEM again, if they making it from paper.
I
will use method shown in the video below. But there are some things they don't tell, like:
Is there any difference where to split old chain? (it has some coloured slots, I suppose?)
I have bought cam locking tool, but it makes no sense to lock them, because according to this video I have to remove them anyway?
And how do I will alling cams and chain later on?
I
https://www.youtube.com/watch?v=KkXqjSDTBjc&t=169s
Will it require some kind of adaptation after replacing chain?
BTW, do You know how to access chain tensioner? Do I need to remove alternator?
Thanks.
you need to remove alternator for access chain tensioner, do not forget reset chain tensioner before re-use otherwise timing chain will over tensioned.
I have new tensioner, it was in set with new chain.
BTW, video states to replace pulse wheels, what's Your take on that?
Without a lift then remove alternator 4th bolt is very dificult and you almost can't remove it fro the top of engine bay, there are two tube hanging over this bolt and you need to remove this tube first before able to access the bolt from bottom.
4 Matic doesn't have that bracket holding the lines you are referring to but still very tight, I always raise the engine a little for more room and use a ratchet wrench
How do You lift the engine? What has to be disconnected? And how high You are able to lift it?
