staggered 20" wheels on my 2011 s500 4 matic
Old Feb 24, 2019 | 08:08 PM
rgzg's Avatar
s550
I put staggered 20" wheels on my 2011 s500 4 matic 8.5 front and 9.5 rear but the rear rubs should I not put the 9.5s on or would a 19" staggered wheels not rub
Old Feb 25, 2019 | 07:20 AM
dlafever's Avatar
'15 S550, '10 E350 P1/P2, '02 ML320
The stock setup on my 2008 S550 is;
Front: 255/40-R19 on 19 x 8.5
Rear: 275/40-R19 on 19 x 9.5
The profile of the tire makes a difference as it is the percentage of the tread width. So if you increase the wheel size, you will likely need to reduce the profile.
Also, if you have tires on the 20" rims that are wider than stock then you may be in for some rubbing and not the good kind.
If you look at the tires/wheels on the S63/S65, they are lower profile (shorter sidewall) but the same width wheel and tire.
Front: 255/35-R20 on 20 x 8.5
Rear: 275/35-R20 on 20 x 9.5
Old Feb 25, 2019 | 10:05 AM
1bad540's Avatar
s550 Diamond white amg pano
there is a bumper tab that can be dremeled off.
Old Feb 25, 2019 | 10:15 AM
Jason B's Avatar
W140 Mercedes S350, W221 S550 sport
PICS PLEASE! That is a requirement of you will be banned.
Old Feb 25, 2019 | 05:44 PM
Rimola's Avatar
G63/X5M
Stupid question. My W222 S550 came staggered. My W221 is 8.5 all around. Did the previous owner change them for whatever reason to be square ?
Old Feb 25, 2019 | 05:47 PM
Jason B's Avatar
that is correct, No W221 came staggered that was a 4-matic. Mercedes didn't do it officially until the w222.
Old Feb 25, 2019 | 05:52 PM
Rimola's Avatar
G63/X5M
That is what I thought or initially was able to gather during my search. Which is why I was a little confused. At least for the 4 matic models.
