2010 S550 Aftermarket Carchex warranty
Old Apr 1, 2019 | 03:54 PM
bshad74's Avatar
2010 S550 W221
I just purchased the warranty from these guys on the following terms: you input and feedback on this would be appreciated - I have a month to cancel it: I am looking for your thoughts and comments if this is a good warranty or am I being screwed: BTW: they never offered Platinum etc to me.
Cost - $4200
Deductible - $200
Duration - 5Y/50K
Limitation - 30 days/1000 Miles waiting before claims
POWERTRAIN PLUS (GOLD) WITH ROADSIDE ASSISTANCE
B. THESE PARTS ARE COVERED:
This CONTRACT covers ONLY the components/parts listed below:
ENGINE (Gas or Diesel): All internally lubricated parts within the Engine including: engine mounts, timing belt, timing gears, cylinder head intake and exhaust valves, valve springs, valve guides, valve seats and oil pump. The engine block and heads are covered only if damage is caused by a FAILURE of any internally lubricated part within the Engine.
TRANSMISSION (Automatic or Standard): All internally lubricated parts within the Transmission including the torque converter and transmission mounts. The transmission case is only covered if damage is caused by a FAILURE of any internally lubricated part within the Transmission. Electronic components, regardless of location, are not covered.
COOLING SYSTEM: Water pump and housings.
TRANSFER UNIT (4x4): All internally lubricated parts within the Transfer Case. The transfer case is only covered if damage is caused by a FAILURE of any internally lubricated part within the Transfer Unit. Electronic components, regardless of location, are not covered.
DRIVE AXLE (FRONT & REAR): All internally lubricated parts within the Drive Axle housings, including the axle shafts and constant velocity joints. The differential housing, transaxle housing and final drive housing are only covered if damage is caused by a FAILURE of any internally lubricated part within the Drive Axle. Electronic components, regardless of location, are not covered.
6. AIR CONDITIONING: Condenser, compressor, evaporator, expansion valve, accumulator/receiver dryer, orifice tube and blower motor.
7. ELECTRICAL: Alternator, voltage regulator, starter motor, ignition switch, front and rear window wiper motors, head lamp switch, turn signal switch, rear defogger switch, air conditioning blower switch, power window motors, power door lock actuators/switches.
8. FUEL SYSTEM: Fuel delivery pump, fuel injection pump, fuel injectors and metal fuel delivery lines.
9. SEALS AND GASKETS: Seals and Gaskets are covered only in conjunction with the repair or replacement of the COVERED PARTS listed in 1 through 8 above. Leaking Seals and Gaskets (as "stand alone" repairs) are not covered by the CONTRACT.
··OPTIONAL COVERAGES··
The following optional coverage’s are included only if selected and an additional charge has been paid as shown on the DECLARATIONS PAGE. Unless the DECLARATIONS PAGE indicates that one or more of the following optional COVERAGES was purchased, the components and coverage’s listed below are also excluded:
LUXURY ELECTRONICS PACKAGE (LEP): The following specifically named VEHICLE Manufacturer/Factory installed parts are covered: Radio/GPS/Navigation Components; integrated radio/GPS; Liquid Crystal Display (LCD) Screens; DVD Players; Rearview Back-up Camera and Sensors; Voice Activation Systems; Standalone seat heaters not integrated in upholstery; Sunroof and Convertible Top Motors. COVERAGE, if purchased, is limited to either 1(one) replacement or 1 (one) repair per component for the life of the Contract.
The above LEP COVERAGE is limited only to FAILURES of the "base unit" and does not cover any remote controls, hand-held controls, wiring, game cartridges, headphones, DVD’s, MP3 Players, programming, or any other non-listed parts for the covered LEP items above. Any aftermarket components are specifically excluded from coverage.
EMISSIONS PACKAGE: If YOU selected and paid an additional charge for the EMISSIONS PACKAGE as shown on YOUR CONTRACT DECLARATIONS PAGE, the following components of YOUR VEHICLE will not be excluded under this CONTRACT: Air Fuel Ratio Sensor/Oxygen Sensor, Air Pump, Barometric Pressure Sensor, Canister Purge Solenoid, EVAP Purge Canister, EVAP Leak detection Pump and Valve, EVAP vent valve, Deceleration Valve, EGR valve, EGR solenoid, EGR check valve, DPFE sensor, EGR controller, EGR diverter valve, EGR relay, Purge Valve, EGR position sensor, EGR lines, EGR/ EFE Thermal Vacuum Switch, EGR/EFE Valve, Engine Oil Fill Cap, Fuel Fill Cap, Fuel Fill Neck Restrictor, Fuel Tank Pressure Sensor, Fuel Tank Vent Valve, Fuel Temperature Sensor, Idle Air Control Valve, Intake Air Resonator, Intake Air Temperature Sensor, MAP Sensor, Mass Air Flow Sensor, PCV Sensor, Air injection control valve, Air injection check valve, Air injection Pump, Air injection Relay.
MARKET LABOR RATE OPTION: If YOU have selected and paid an additional charge for the MARKET LABOR RATE OPTION as shown on YOUR CONTRACT DECLARATIONS PAGE, the maximum payable repair facility labor rate of one hundred dollars ($100) per hour set forth in Section F. 13 of this CONTRACT shall not apply, and the ADMINISTRATOR will authorize repairs for covered MECHANICAL BREAKDOWN or FAILURE based upon the REPAIR FACILITY’s posted labor rate.
COVERAGE for components listed in this OPTIONAL COVERAGES SECTION supersedes those excluded in the exclusions section of this CONTRACT only if the applicable surcharge has been paid and noted on the DECLARATIONS PAGE.
C. ADDITIONAL BENEFITS
The following ADDITIONAL BENEFITS for YOUR covered VEHICLE are provided with YOUR CONTRACT, except where prohibited by law. These benefits do not apply during the WAITING PERIOD:
ROADSIDE ASSISTANCE: YOUR CONTRACT provides YOU with an emergency road service program when needed, 24 hours a day, 365 days a year. Emergency Roadside services are provided by Roadside Protect, Inc. powered by Signature’s Nationwide Auto Club, Inc. If YOUR VEHICLE becomes disabled, call 866-222-7869 and a service vehicle will be dispatched to YOU. There is a combined four hundred dollar ($400) maximum limit for such emergency road service benefits as listed below for the term of YOUR CONTRACT. YOUR CONTRACT DEDUCTIBLE does not apply to roadside assistance. YOUR ROADSIDE ASSISTANCE BENEFITS include:
TOWING SERVICE: If YOUR VEHICLE cannot be started or driven, YOU are covered up to seventy-five dollars ($75) per occurrence for towing expenses.
b. EMERGENCY TIRE SERVICE: If YOUR VEHICLE has a flat or damaged tire, YOU are covered up to a maximum of seventy-five dollars ($75) per occurrence for service to change an inflated spare provided by YOU.
c. LOCKOUT SERVICE: If YOU misplace, break, or accidentally lock YOUR keys in YOUR VEHICLE, dispatch will provide locksmith or emergency VEHICLE service to assist YOU. Lockout service is limited to seventy-five ($75) per occurrence. The cost of new keys is not covered.
d. BATTERY SERVICE: If the battery for YOUR VEHICLE fails, battery jump start services will be provided up to a maximum of seventy-five dollars ($75) per occurrence.
e. FUEL DELIVERY SERVICE: In case it is necessary for the operation of YOUR VEHICLE, a service VEHICLE will deliver oil, fuel, or water to YOU. YOU are responsible for the cost of the oil and fuel. In the event that local state regulations prohibit the delivery of flammable materials (e.g., gas), YOU may have YOUR VEHICLE towed to the nearest gas station as provided under the "Towing Service" paragraph above. Fuel Delivery services are limited to seventy-five dollars ($75) per occurrence.
WINCHING: YOU are covered for winching services provided YOUR VEHICLE is within one hundred (100) feet of a public road (excludes off-road driving). Winching services are limited to seventy-five dollars ($75) per occurrence.
CAR RENTAL REIMBURSEMENT: If YOUR VEHICLE becomes inoperable and must remain at the REPAIR FACILITY and the MECHANICAL BREAKDOWN or FAILURE has been authorized by the ADMINISTRATOR for four (4) or more hours of labor, the ADMINISTRATOR agrees to reimburse YOU for rental car transportation from a licensed vehicle rental company (except where prohibited by law). Such expense shall be limited to forty dollars ($40) per calendar day not to exceed one hundred sixty dollars ($160) per occurrence including delays associated with ADMINISTRATOR required inspections or the shipment of parts needed for covered repairs. WE reserve the right to select the rental car company that YOU use. YOUR car rental benefit is based upon the number of labor hours required to repair YOUR VEHICLE as listed in a nationally recognized labor time guide selected by the ADMINISTRATOR. Each additional eight (8) hours of authorized labor qualifies YOU for an additional day of rental reimbursement, subject to the forty (40) dollars per day and one hundred sixty (160) dollars per occurrence limit of liability, as well as the aggregate limit of liability for this Contract. Rental car benefits require prior authorization by the ADMINISTRATOR.
TRIP INTERUPTION REIMBURSEMENT: If YOUR VEHICLE becomes inoperable more than one hundred (100) miles from YOUR home and must remain at the REPAIR FACILITY overnight as a result of a MECHANICAL BREAKDOWN or FAILURE authorized by the ADMINISTRATOR, WE will reimburse YOU for motel and restaurant expenses up to fifty (50) dollars per day for a maximum of three (3) days. The maximum benefit per occurrence is one hundred fifty (150) dollars and total trip interruption benefits are subject to the aggregate limit of liability for this Contract. To receive motel and restaurant reimbursement, YOU must supply US with receipts from the providers of such services.
D. EXCLUSIONS – The following items are not covered by this CONTRACT:
1. REPAIR OR REPLACEMENT OF ANY PART(S) THAT ARE NOT LISTED AS "COVERED PARTS" IN SECTION B OF THIS CONTRACT;
2. MECHANICAL BREAKDOWN OR FAILURE:
A. WHEN REPAIRS ARE PERFORMED WITHOUT PRIOR AUTHORIZATION FROM THE ADMINISTRATOR, EXCEPT FOR EMERGENCY REPAIRS COMPLETED IN CONFORMITY WITH THE PROVISIONS AND SUBJECT TO THE LIMITATIONS SET FORTH IN SECTION F, PARAGRAPH 11;
B. CAUSED BY A LACK OF MAINTENANCE OR MAINTENANCE ITEMS SUCH AS, BUT NOT LIMITED TO, CONSTANT VELOCITY JOINT BOOTS, TIMING BELT, BRAKE PADS OR SHOES, FILTERS, OIL AND OTHER FLUID CHANGES ;
C. CAUSED BY ACTS OF NATURE, OR BY ANY EXTERNAL CAUSE SUCH AS, BUT NOT LIMITED TO: COLLISION, FIRE OR SMOKE, THEFT, FREEZING, VANDALISM, RIOT OR EXPLOSION, TERRORISM, LIGHTNING, EARTHQUAKE, WINDSTORM, HAIL, VOLCANIC ERUPTION, WATER OR FLOOD, BREAKAGE OF GLASS, FALLING OBJECTS, OR NUCLEAR CONTAMINATION;
D. OF ANY OTHERWISE COVERED PART THAT DID NOT MEET MANUFACTURER’S SPECIFICATIONS, INCLUDING MODIFICATIONS AND/OR ALTERATIONS TO THE VEHICLE; MECHANICAL BREAKDOWN OR FAILURE OF ANY OTHERWISE COVERED PART THAT IS DIRECTLY OR INDIRECTLY RELATED TO A PART OR SYSTEM THAT DID NOT MEET MANUFACTURER’S SPECIFICATION OR HAS BEEN OTHERWISE MODIFIED OR ALTERED, SUCH PARTS AND MODIFICATIONS INCLUDE BUT ARE NOT LIMITED TO:
HEADERS, ALTERED IGNITION SYSTEM, ALTERED ENGINE MANAGEMENT SYSTEMS, FREE FLOW EXHAUST SYSTEM, AFTERMARKET SUNROOFS, AFTER MARKET ALARM SYSTEMS, SNOW PLOWS, OVERSIZED OR UNDERSIZED TIRES, WHEELS OR LIFT AND DROP KITS, WHETHER OR NOT THE VEHICLE WAS PURCHASED WITH SUCH;
E. IF YOUR VEHICLE IS USED FOR: RACING ON OR OFF ROAD, IN A COMPETITION OR SPEED CONTEST;
F. IF YOUR VEHICLE IS USED FOR TOWING IN EXCESS OF TWO THOUSAND (2,000) POUNDS UNLESS EQUIPPED WITH A FACTORY APPROVED TOWING KIT AND AUXILIARY TRANSMISSION COOLER, AND THE WEIGHT OF THE TRAILER DOES NOT EXCEED THE VEHICLE MANUFACTURER’S TOWING SPECIFICATION;
G. IF YOUR VEHICLE IS USED FOR COMMERCIAL PURPOSES EXCEPT WHEN THE VEHICLE IS ELIGIBLE FOR COVERAGE AS DESCRIBED IN SECTION G. "COMMERCIAL VEHICLES" OF YOUR CONTRACT;
H. OF ANY PART(S), COMPONENT(S), OR REPAIR(S) STATED AS COVERED BY THE MANUFACTURER’S FULL, ORIGINAL OWNER/FIRST RETAIL PURCHASER WARRANTY FOR THE TERM AND MILEAGE OF SUCH COVERAGE TO THE ORIGINAL OWNER/FIRST RETAIL PURCHASER, WHETHER COLLECTIBLE OR NOT, OR CONTINUING MANUFACTURER’S WARRANTY COVERAGE THAT IS TRANFERABLE TO SUBSEQUENT OWNER WHETHER TRANSFERRED OR NOT;
I. IF THE COVERED PART IS COVERED BY A MANUFACTURER’S WARRANTY, REPAIRER’S GUARANTEE, OR OTHER SERVICE CONTRACT, OR INSURANCE POLICY OF ANY TYPE THEN SUCH WARRANTY, SERVICE CONTRACT OR INSURANCE SHALL BE PRIMARY AND COVERAGE UNDER THIS CONTRACT SHALL BE SECONDARY;
J. RELATED TO OPTIONAL COVERAGES OR EQUIPMENT AND/OR USE FOR WHICH A SURCHARGE IS APPLICABLE, UNLESS SUCH SURCHARGE HAS BEEN PAID AND IS NOTED ON THE DECLARATION PAGE;
K. IF IT IS DETERMINED THAT THE ODOMETER IS INACCURATE, HAS EVER BEEN INOPERATIVE, OR HAS BEEN ALTERED SUCH THAT THE VEHICLE’S TRUE MILEAGE CANNOT BE VERIFIED;
L. THAT IS THE RESULT OF A DEFECT THAT THE VEHICLE MANUFACTURER HAS ANNOUNCED AS THEIR RESPONSIBILITY BY A PUBLIC RECALL, TECHNICAL SERVICE BULLETIN AND/OR SPECIAL POLICY FOR THE PURPOSE OF CORRECTING SUCH A DEFECT;
M. DUE TO CONTINUED OPERATION AND FAILURE TO PROTECT THE VEHICLE FROM FURTHER DAMAGE ONCE A MECHANICAL BREAKDOWN OR FAILURE HAS OCCURRED;
N. OF A COVERED PART DAMAGED BY A NON-COVERED PART, OR OF A NON-COVERED PART DAMAGED BY A COVERED PART;
O. CAUSED BY MISUSE, ABUSE, NEGLIGENCE, INCORRECT COMPUTER PROGRAMMING, EXTERNAL NUTS, BOLTS, FASTENERS, CONTAMINATION OF COOLANT, FUEL, FLUIDS OR LUBRICANTS;
P. RESULTING FROM OVERHEAT, ENGINE SLUDGE, CARBON, PRE-IGNITION,
DETONATION, VARNISH, RUST, CORROSION, FOREIGN OBJECTS, DIRT, DUST, LIQUID, CRACKED RUBBER / NEOPRENE PARTS, DRY-ROT, ROAD CHEMICALS, ABUSE, ALTERATION, OR LACK OF PROPER AND NECESSARY AMOUNTS OF COOLANT, FUEL, FLUIDS OR LUBRICANTS;
Q. PRE-EXISTING CONDITIONS THAT EXISTED PRIOR TO THE LATER OF YOUR CONTRACT PURCHASE DATE OR CONTRACT EFFECTIVE DATE AS LISTED ON YOUR DECLARATIONS PAGE AND THE COMPLETION OF YOUR WATING PERIOD;
R. THAT OCCURRED OR IS REPORTED AFTER YOUR CONTRACT EXPIRATION OR CANCELLATION EFFECTIVE DATE;
S. FOR REPAIR OR REPLACEMENT OF HYBRID ENGINE POWERED VEHICLE BATTERIES OR FOR THE REPAIR OR REPLACEMENT OF PARTS ASSOCIATED WITH HYBRID ENGINE POWERED VEHICLE BATTERIES;
T. THAT OCCURS AS TO GRADUAL LOSS OF PERFORMANCE AND HAS RESULTED FROM NORMAL OPERATION AND USE (DUE TO VEHICLE MILEAGE AND/OR AGE) SUCH AS, BUT NOT LIMITED TO: VALVE GUIDES, VALVES, PISTON RINGS, TRANSMISSION CLUTCH PACK DISCS AND BANDS. UNLESS WORN BEYOND MANUFACTURER TOLERANCES;
U. FOR NORMAL EXPANSION/CONTRACTION SEEPAGE OF SEALS AND GASKETS DUE TO AGE/MILEAGE;
V. WHEN THE MANUFACTURER’S NEW VEHICLE WARRANTY HAS BEEN DETERMINED NULL AND VOID BY THE MANUFACTURER.
3. STORAGE AND FREIGHT CHARGES;
4. REPAIRS NECESSITATED BY AN IMPROPER PRIOR REPAIR;
5. THE COST OF DIAGNOSIS, TEARDOWN, DISASSEMBLY OR ASSEMBLY IF A COVERED MECHANICAL BREAKDOWN OR FAILURE CANNOT BE VERIFIED BY THE ADMINISTRATOR;
6. ANY ADJUSTMENTS, REPOSITIONING, REFITTING, REALIGNING AND/OR CLEANING, INCLUDING BUT NOT LIMITED TO REPAIRS NECESSARY TO CORRECT: TRIM FIT, SQUEAKS, RATTLES, IDLE, WATER LEAKS OR WIND NOISE;
7. REPAIRS IF YOUR VEHICLE IS: A NON-U.S. SPECIFICATION MODEL, IS RATED OVER ONE TON PAYLOAD CAPACITY, IS A LEMON LAW BUYBACK VEHICLE, IS A GREY MARKET VEHICLE OR HAS EVER HAD A TITLE INDICATION OF SALVAGE, JUNK, BRANDED OR OTHER DESIGNATION INDICATING THAT THE VEHICLE HAD BEEN STOLEN, WRECKED, DESTROYED, WATER DAMAGED, OR OTHERWISE DAMAGED TO THE EXTENT THAT IT WAS CONSIDERED TO BE UNECONOMICAL TO REPAIR;
8. NORMAL MAINTENANCE ITEMS, PARTS, AND PROCEDURES SUCH AS, BUT NOT LIMITED TO: ENGINE TUNE-UPS, OIL CHANGES, BRAKE PADS AND SHOES, FUSES AND FUSABLE LINKS, FUSE BOXES, COMPUTER PROGRAMMING, WHEEL OR SUSPENSION ALIGNMENT, FASTENING HARDWARE (EXTERNAL NUTS, BOLTS, SPRINGS, BRACKETS, ETC.), INJECTOR CLEANING, SHOP SUPPLIES, DISPOSAL FEES AND OTHER MISCELLANEOUS SHOP CHARGES;
9. LUBRICANTS, COOLANTS AND FLUIDS UNLESS REQUIRED IN CONNECTION WITH A COVERED REPAIR;
10. ANY PART THAT HAS NOT BROKEN OR FAILED, BUT FOR WHICH A REPAIR FACILITY RECOMMENDS OR REQUIRES REPAIR OR REPLACEMENT;
11. THE REPAIR OR REPLACEMENT OF VALVES AND/OR PISTON RINGS FOR THE PURPOSE OF RAISING THE ENGINE’S COMPRESSION OR CORRECTING OIL CONSUMPTION, STICKING OR STUCK RINGS, WHEN MECHANICAL BREAKDOWN OR FAILURE HAS NOT OCCURRED, INCLUDING WHEN SUCH CONDITION RESULTS FROM EXCESSIVE CARBON BUILD-UP.
12. ANY REPAIR IF VERIFIABLE RECEIPTS, AS REQUIRED IN SECTION E. VEHICLE MAINTENANCE REQUIREMENTS," ARE NOT PROVIDED IF REQUESTED BY THE ADMINISTRATOR;
13. ANY COMPONENTS, PARTS OR COSTS INVOLVED WITH UPDATING, BETTERMENT, OR RETROFITTING OF COVERED COMPONENTS OR SYSTEMS OF YOUR VEHICLE FOR ANY REASON INCLUDING BUT NOT LIMITED TO:PRODUCT CHANGES, LACK OF PRODUCT AVAILABILITY, OR GOVERNMENT REGULATIONS;
14. REPAIRS TO CURE FLUID/OIL LUBRICANT SEEPAGE;
15. SHOP SUPPLIES AND HAZARDOUS WASTE REMOVAL ARE EXCLUDED;
16. RETROFITS OR REPLACEMENTS OF ANY COMPONENTS CAUSED BY OR DUE TO COMPLIANCE WITH LAW OR LEGISLATION, AND INCLUDING EMISSION CONTROL EQUIPMENT AND SENSORS ARE EXCLUDED;
17. IF IT IS DISCOVERED THAT A CONTRACT IS ERRANTLY SOLD TO YOU ON AN INELIGIBLE VEHICLE, THEN A FULL REFUND OF THE COST OF THE CONTRACT SHALL BE MADE TO YOU;
18. LOSS OF TIME, INCONVENIENCE, DAMAGE TO PROPERTY OR OTHER INCIDENTAL OR CONSEQUENTIAL DAMAGE THAT RESULTS FROM VEHICLE THEFT, MECHANICAL BREAKDOWN OR FAILURE, AND INJURY AND/OR DEATH OF ANY PERSON REGARDLESS IF THE DAMAGE OR INJURY WAS CAUSED BY YOUR VEHICLE OR ITS PARTS EITHER BEFORE OR AFTER REPAIRS HAVE BEEN MADE;
19. VEHICLES NOT INCLUDED IN ADMINISTRATOR’S RATE AND CLASS GUIDES, INCLUDING BUT NOT LIMITED TO MOTOR HOMES, MOTORCYCLES, RECREATIONAL VEHICLES, VEHICLES USED FOR AGRICULTURAL PURPOSES, EXOTIC VEHICLES, VEHICLES EQUIPPED WITH A SNOW PLOW, BRACKET AND/OR CONTROLS ARE NOT ELIGIBLE FOR COVERAGE UNDER THIS CONTRACT;
20. FAILURES TO THE AIR BAGS, SEAT BELTS OR SUPPLEMENTAL RESTRAINT SYSTEMS.
F. IN THE EVENT OF A MECHANICAL BREAKDOWN OR FAILURE:
1. YOU shall protect the VEHICLE from further damage whether or not such MECHANICAL BREAKDOWN or FAILURE is covered by YOUR CONTRACT. Any operation of the VEHICLE that results in further damage related to the original MECHANICAL BREAKDOWN or FAILURE shall be considered negligence on YOUR part and any such further damage shall not be covered under this CONTRACT. YOU are responsible for making sure that all VEHICLE fluids are full and that the oil warning light/gauge and temperature warning light/gauge are functioning before driving the VEHICLE. YOU are required to safely pull YOUR VEHICLE off of the road and shut off the engine immediately when any of the lights/gauges indicate a problem.
2. Present this CONTRACT to the REPAIR FACILITY and call the ADMINISTRATOR, toll free at 1-800-531-1925.
3. The ADMINISTRATOR will determine the validity of the CONTRACT: proper owner, proper VEHICLE, that the CONTRACT is still in force and that payments are current if you enrolled in a payment plan at the time of purchase of this CONTRACT.
4. YOU are responsible for authorizing and paying for any tear down and/or diagnosis time needed to determine if the VEHICLE has a covered MECHANICAL BREAKDOWN or FAILURE. This CONTRACT will not cover flat rate charges for diagnosis. If the breakdown is not caused by a covered MECHANICAL BREAKDOWN or FAILURE, YOU are responsible for payment of the expenses associated with the tear down and diagnosis.
5. Prior to proceeding with repairs, ensure the REPAIR FACILITY calls the ADMINISTRATOR with an estimate of repairs and receives an authorization number from the ADMINISTRATOR. ADMINISTRATOR will not be liable for repairs performed without prior ADMINISTRATOR authorization, regardless of whether or not you have authorized the REPAIR FACILITY to complete the repairs. Except for emergency repairs performed in accordance with and subject to the limitations included in F.11, any repair performed without prior authorization from the ADMINISTRATOR will not be covered.
6. The ADMINISTRATOR will verify COVERAGE, confirm the cost of repair using nationally recognized labor guides, authorize repair of COVERED PARTS and labor, and provide the REPAIR FACILITY with an authorization code.
7. The ADMINISTRATOR reserves the right to inspect YOUR VEHICLE prior to issuing any authorization to the REPAIR FACILITY. In the event of a dispute between the ADMINISTRATOR and the REPAIR FACILITY, the ADMINISTRATOR reserves the right to move YOUR VEHICLE to a REPAIR FACILITY of the ADMINISTRATOR’S choice.
8. At the ADMINISTRATOR’S election, repair or replacement of COVERED PARTS will be made with parts of like kind and quality, including but not limited to new, re-manufactured, exchanged, or used components.
9. In-home repair (both self and mobile) is not covered under this CONTRACT. Any payment for the cost of transporting the VEHICLE to a REPAIR FACILITY as a result of an in-home repair effort, or
expenses related to correction of ineffective or failed self-repair efforts is not covered.
10. YOU are responsible for paying any amounts not covered by this CONTRACT, including but not limited to the DEDUCTIBLE, for each visit to the REPAIR FACILITY.
11. Reimbursement for emergency repairs performed outside of normal business hours may be obtained by YOU only if YOU contact US no later than the first business day after such emergency repairs are performed and such emergency repairs meet the following criteria:
a. The MECHANICAL BREAKDOWN or FAILURE must prevent YOU from safely operating YOUR VEHICLE.
b. The need for repair is immediate and the ADMINISTRATOR’S office is closed.
c. The MECHANICAL BREAKDOWN or FAILURE must be of a covered component of YOUR VEHICLE.
The total cost of the repair and/or replacement must not exceed two hundred fifty dollars ($250.00). For any repair or replacement with a cost exceeding two hundred fifty dollars ($250.00), YOU must obtain ADMINISTRATOR’S prior authorization as set forth above or any amount in excess of two hundred fifty dollars ($250.00) will not be covered and will be YOUR responsibility.
12. The ADMINISTRATOR will make payment directly to the REPAIR FACILITY or to YOU for the covered and authorized repairs or additional CONTRACT benefits. The form of payment will be decided by the ADMINISTRATOR.
13. The maximum hourly rate to be paid on any covered repair will be determined based on average REPAIR FACILITY labor rates for the zip code area and VEHICLE type as determined by the ADMINISTRATOR, but not to exceed one hundred dollars ($100) per hour. Any labor charges over one hundred dollars ($100) per hour will be YOUR responsibility in the event the repair facility will not accept our allowed rate and YOU choose to have repairs made at that repair facility. The one hundred dollar ($100) per hour limitation shall be eliminated in the event the market labor rate option has been paid for and is listed on the DECLARATIONS PAGE.
G. COMMERCIAL VEHICLES
1. This CONTRACT may be available for certain types of COMMERCIAL VEHICLES as long as: (a) the VEHICLE is not rated over one (1) ton payload capacity and; (b) the appropriate surcharge is paid at time of CONTRACT purchase.
2. Only the following commercial applications are eligible for coverage under this contract: delivery, messenger, route sales or services, inspections/examinations, maintenance or repair, gardening, and carrying hand tools to the job site.
3. COMMERCIAL VEHICLES are required to follow all original manufacturer’s severe service scheduled maintenance and must not exceed maximum towing/load capacities. For specific information, consult YOUR owner’s manual or a dealer who sells the make of YOUR VEHICLE.
4. VEHICLES used in any commercial manner not provided in G.2. above are not eligible for
COVERAGE. Commercial uses not eligible for coverage include but are not limited to; taxi, limousine, shuttle, police or other emergency use, security service or any law enforcement agency, snow plowing, towing.
5. Any VEHICLE used as a rental or loaner is not eligible for coverage.
VEHICLES rated over one-ton payload capacity and fleet VEHICLES are not eligible for COVERAGE.
Old Apr 1, 2019 | 08:03 PM
xabo's Avatar
'20 S63
I had the platinum on my CL65................it expired in February of this year. Paid for itself over the 3 years that I had it. Had the motor/transmission mounts replaced twice, blower motor, broken coolant line to one of the turbos replaced ($8000) and the command unit among other things. Only issue was they would only pay for aftermarket parts. My service advisor would only install OEM parts which he give a 10% discount on and I would pay the difference.
They even covered replacement of coil pack after the warranty had expired.
Old Apr 1, 2019 | 08:57 PM
bshad74's Avatar
2010 S550 W221
Who did you have the warranty with and how much did you pay
If you don't mind me asking? What was covered and what wasn't?
Old Apr 1, 2019 | 09:33 PM
xabo's Avatar
'20 S63
Pretty much the standard exclusionary warranty. The Platinum covered the electronics...............command unit, modules etc.
Old Apr 3, 2019 | 01:28 PM
bshad74's Avatar
2010 S550 W221
My 2010 S550 has 88K miles - any suggestions on warranty companies - the one I got only has power train (listed above) and no one is willing to cover pumper to pumper.
Old Apr 3, 2019 | 03:54 PM
Kevo79's Avatar
s63
I’d be interested in this for my s63 I’ve been looking.
Old Apr 4, 2019 | 02:08 PM
xabo's Avatar
'20 S63
Sample..........................
Old Apr 4, 2019 | 04:46 PM
cbrea1418's Avatar
2009 C300 4matic Sport
how much hassle did they give you to actually get the cash/parts?
Old Apr 4, 2019 | 05:35 PM
xabo's Avatar
'20 S63
See post #2
Old Apr 4, 2019 | 07:48 PM
cbrea97's Avatar
'09 C300 4matic (w204)
See post #2
you are aware that mercedes does not actually manufacture car parts, right? They may design them but they are made by various suppliers. So going aftermarket if you know what you are looking for- just means saving 100s if not 1000s on a simple branding label. My question was not geared towards what they cover, i got that part. Its if they would give you the run around when you filed a claim. Some companies let you file claims out the wazoo and they wont honor a single one. My question is more like: Did they follow through with a claim without you having to call/write multiple times? Maybe a generic response with no clear answer as to the fact that they are considering fulfilling your claim... or did you call once, an adjustor showed up and boom- check in the mail.
Old Apr 4, 2019 | 08:11 PM
bshad74's Avatar
2010 S550 W221
I haven't used the warranty as of yet so don't know. But heard good things about carchex on this forum.
Old Apr 4, 2019 | 08:17 PM
xabo's Avatar
'20 S63
"Only issue was they would only pay for aftermarket parts. My service advisor would only install OEM parts which he give a 10% discount on and I would pay the difference.
They even covered replacement of coil pack after the warranty had expired."
