Flooded S550 I need help
Old Jun 10, 2019 | 09:46 AM
  #51
konigstiger's Avatar
'71 Pinto
If by code you mean model code it is 221.194, post VIN I will provide MB data card (equipment codes, etc.) WIS (VIN specific parts #, instructions, etc.) check here: https://www.ebay.com/sch/i.html?_fro...edes+&_sacat=0 as it concerns general wiring diagrams you can check here: http://www.bbbind.com/tsb-and-wiring...ense-agreement
Old Jun 11, 2019 | 02:48 PM
  #52
Kevin Sahib's Avatar
2012 s550
Old Jun 11, 2019 | 03:04 PM
  #53
'71 Pinto
6/30/11
File Type: pdf
Old Jun 11, 2019 | 04:15 PM
  #54
07CL550Benz's Avatar
2007 CL550
Yes I've got seat bolts and some of the rail covers. I need to do my interior swap and see what I have left over.
Old Jun 11, 2019 | 06:00 PM
  #55
MBS430's Avatar
S550 , S430
you are making GREAT progress!! I didnt think you would get this far. keep up the good work, you will be cruising in a smooth S550 soon! I'll be following your progress
Old Jun 11, 2019 | 07:40 PM
  #56
2012 s550
What color are the brakets you got
  #57
2012 s550
Thanks i really appreciate the support
Old Jun 11, 2019 | 07:43 PM
  #58
2012 s550
How do I get a wiring diagram for the back of the front sam module and fuse box, i know they exist i seen it for different models but just can't find it for w221
Old Jun 13, 2019 | 01:01 AM
  #59
2012 s550
finally i got the AC working , blowing ice cold now , heat works too
now the only two things are not functioning in the car are the Hazard lights (turn signal lights works)
and the massage seats (some times they do work then they stop)
where should i start looking
Old Jun 13, 2019 | 03:15 AM
  #60
2007 CL550
I wouldn't count on me for the rail covers. I need to do my swap first and then I can see what I have leftover. I think that hazard light switches go bad in these cars, I had to replace the COMAND control buttons on my CL for the same reason.
Old Jun 13, 2019 | 05:25 AM
  #61
2012 s550
For wherever it's worth, here's another update
I couldn't sleep so i tore apart the plastic wire covers and discovered an air line leake on the side of back seat tapted really good and now the massage function %100
I also took apart the center console to get to the hazard light switch, but i couldn't figure out how to access it, there was a black plastic peace behind it and to torx screws i took them out and nothing happened, so i gave up and put everything back to place, i'm thinking about leaving this one thing broken ���� so that nothing else brakes (old myth) ��
Old Jun 13, 2019 | 11:20 AM
  #62
'71 Pinto
Unless you’re saying button is physically damaged and needs replacement: http://www.bbbind.com/tsb-wiring-diagrams-database/ - wiring diagrams - enter “2011” s550 - 7445470 & 7445471 upper control panel - A40/9s3 Hazard warning system button originates from N72/1 upper control panel in dash located under center A/C vents.
Old Jun 13, 2019 | 12:55 PM
  #63
2007 CL550
You need to pry the silver cap off the comand knob and then there is a screw there to remove.
Old Jun 13, 2019 | 11:39 PM
  #64
2012 s550
she's back together and she's looks great, thanks for everyone that helped.
question: i have the Auxiliary battery malfunction message, i replaced the battery and still get the message, any idea?
Old Jun 14, 2019 | 08:08 AM
  #65
boardboy330's Avatar
2000 ML320, 2005 E320 CDI
Great progress. Interesting thread since my car flooded yesterday on the way to work
Old Jun 14, 2019 | 08:10 AM
  #66
2012 s550
Sorry to hear that, how baf is it?
Old Jun 14, 2019 | 04:26 PM
  #67
Didn't dig into it hard, but water was up to the windows. Motor died under water. Was there for maybe 15 minutes until it was pulled out. Mechanic said the starter is shot. Have to replace but won't know if the Alternator is bad til we turn it over. The windshield is cracked, bumper needs paint. Drivers headlight needs replaced. both bulbs. 2 front wheels. Roughly $5K in damage. Virginia has a law that more than $3500 in water damage is a total loss. I am heartbroken, honestly.
The car powers up but will not turn over or even try to crank.
Old Jun 14, 2019 | 04:45 PM
  #68
2012 s550
Damn that's a lot of damage, check the fuse box next to the battery this is the first thing that will go out
Old Jun 14, 2019 | 05:04 PM
  #69
Already did. Checked all fuse boxes, not a single fuse blew that I found (or my Mechanic).
Only codes I got were:
P0155 O2 Sensor (presume water in the exhaust)
P0365 Camshaft Position B
P0695
Key in and on, everything lights up like I am about to start the car. Just won't start. Sucks.
Old Jun 14, 2019 | 10:02 PM
  #70
Donnymac's Avatar
63 Falcon vert
Kevin Sahib.......you did a great job. Congratulations!
Old Jun 14, 2019 | 10:15 PM
  #71
1bad540's Avatar
s550 Diamond white amg pano
Nice, any other pics of the car?
Old Jun 14, 2019 | 10:36 PM
  #72
2012 s550
Coming up soon, i need to get a tire replaced and some missing pieces and we'll be all set
Old Jun 14, 2019 | 10:41 PM
  #73
2012 s550
Okay i can wait on the brakets no big deal.
Now do you have the following :
2 bolts for the seats
Cup holders braket
Exhaust tip for passenger side
Tow hook covers front and back
Hazard light switch (the whole apparatuses)
1 cornering light
1 rear fog lamp
Old Jun 16, 2019 | 03:13 AM
  #74
2012 s550
Small update
I got the auxiliary battery working it was a blown fuse, car is %99 done
Only thing left is some cosmetic stuff and 1 cornering light, i can't figure out how to pull it out, and didn't find any info about it. So if anyone knows please help, and if you have a part number that would be great.
Oh and I'm waiting to get inspection done so i can finally drive this thing, can't wait
Ps: hazard lights still not working i need to find a deal on a good used one
Old Oct 29, 2019 | 12:17 AM
  #75
2012 s550
5 months update
it's been about 5 months since i fixed the S550 and i'm happy to report she's doing Great , zero issues, working flawlessly. i took it to disney world from ohio and had a fantastic trip , also took couple trips to nearby states and put about 5k miles on it
here's some pics
