Obd not reading
Old Jul 19, 2019 | 04:44 AM
tray will's Avatar
s600
Obd not reading
I have a 2008 s600 that’s in limp mode I try to connect several scanners to it including an expensive scan tool it would not read. The scanner powers on but wit not connect to car to read codes any idea what’s wrong ?
Old Jul 20, 2019 | 07:58 AM
antiguangenius's Avatar
2008 S550 4Matic, 2007 GL450, 2008 C300, 2018 GLE63 AMG
blown fuse for the diagnostic module
Old Jul 20, 2019 | 04:56 PM
MBENZTECH's Avatar
W203 W212 W211 R53MCS
If you have power and ground at the OBD2 connector and no communication is available..... Then check your central gateway module.
Old Jul 21, 2019 | 07:29 PM
if central gateway is down the dashboard will be a Christmas tree
Old Jul 27, 2019 | 02:02 PM
Polar Bear's Avatar
W221 S600, W220 S55 AMG Kompressor, W124 300E, W140 S320, W210 E3204M W164 ML320 Bluetec
The fact it is in limp home mode could be related. Have you disconnected the battery/batteries, reconnected and checked again?
Old Jul 28, 2019 | 09:49 PM
Maybe your ecu is defective, it's not reading the vin, some scanners if they don't read vin the won't connect, do a manual vin entry then read modules one by one
