SAT RADIO FUNCTION MAGICALLY DISAPPEARED!!
Old Aug 3, 2019 | 09:37 AM
Tgreifer's Avatar
2007 S550 4Matic
Has anyone had the SAT Radio option disappear from your audio options!?
All other functions perform fine. I was listening to the satellite radio, then changed and listened to a CD one day, then I went to change back to SAT Radio and the option was no longer there! I NEED my SAT radio!! any help is appreciated.
Old Aug 3, 2019 | 10:27 AM
konigstiger's Avatar
'71 Pinto
Find module located behind left trunk panel (see photo) disconnect/reconnect black connector in an attempt to re-establish MOST loop. If this fails may need to find someone with MB Xentry (diagnostics) to pull codes, reset, and/or check for software update. If ultimately it winds up being module here are compatible part #s for replacement.
File Type: pdf
Old Aug 3, 2019 | 11:07 AM
Tgreifer's Avatar
2007 S550 4Matic
Thanks!! I have already tried a different module. I may dig in a bit today and see if there’s anything else I can find before getting it into the dealer.
Old Aug 5, 2019 | 05:35 PM
steveb9771's Avatar
2007 CL550
Try to access it using the voice command "SAT RADIO". Sometimes this works when all else fails.
Old Apr 12, 2020 | 03:22 PM
Tgreifer's Avatar
2007 S550 4Matic
Here is the update!!
I caved in and took the car into the dealer. They said that they have never seen this happen before. They completely reprogrammed the system and added it back in. Works fine now.
Old Apr 13, 2020 | 01:15 AM
The Thomas J's Avatar
2010 MB S550, 2017 MB SLC 300
Thanks for the update! Glad ti worked out.
Old Apr 13, 2020 | 05:47 AM
BOTUS's Avatar
S500
there was another post recently about sirius just vanishing
I doubt an intentional extra (that Mercedes are slipping in to later cars) but I would guess somewhere a bug (maybe a date) in part of the infotainment software times out and a wobble comes in to play
