Need serious tramission help from you guys
Now the issue I have which is effecting me most is I'm not able to scan the car, scanner is unable to catch vin no nor does it scan any model when I manually select it too.
Car won't start and I can't scan
I tried to remove the ism module connector thinking that might be the reason for the fault but it would not start even after removing the connector also.
Now the car was in D when I was driving. But when it turned off it went into P I know that because when u push the car also it won't move.
Please help me understand why can't I scan it and what could be wrong with it
Thanks a ton for your help in advance
