W221 (M278) Oil and Filter Changing Video.
Old 04-08-2021, 08:29 PM
Andrew Alzate's Avatar
2004 mercedes s430
My mercedes started turning on the whipers and the lights inside
Hi I don't know if I'm doing this right , is the first time I used this blog, I notice that today my mercedes s430 started activating the windshield wipers by it self , and some of the interior lights as well, this has not happen in the past , at least that I know, and the radio has been acting it turns on and off by it self , can any one recommend a solucuon to this problems please
Originally Posted by EasyPhil
Nice video, you have a great set up! Two tips:
You might want to consider using the suction method to change your oil which doesn't require you to jack up the car and get under it. This is the method they use at the dealer and works well as the oil dipstick extends all the way to the bottom of the tank and all you need to do is make an airtight fit at the top of the tube and use a fluid extractor to pump the oil out. The other tip is to pour the bulk of the oil in to the oil filter opening prior to closing it with the new filter.
Old 05-31-2021, 01:03 PM
riv-stage 1's Avatar
2012 s550 4matic
Andrew Alzate, you should ask your question on a new thread ( since your question doesn't relate to this thread) and you might need to put it in the w220 section since it appears your car is NOT a w221 ( MB never made a 430 on w221 platform)
hope that helps to get your question answered more quickly
Old 06-27-2021, 11:17 PM
2012 s550 4matic
for jacking up the back side of the car, are you using the jacking point of the Differential? I don't see any other place?
Old 06-27-2021, 11:45 PM
39039's Avatar
W221 S550 4MATIC
Yes, and all of details on
Quick Reply: W221 (M278) Oil and Filter Changing Video.
