s63 cluster Help me exchange it!
Old Oct 11, 2019 | 05:46 AM
Ahn Hyun Jin's Avatar
w221 s500
Thumbs up s63 cluster Help me exchange it!
Hi, everyone. I live in Korea!
my car 2006 w221 s500
I want to replace w221 s63 with an instrument panel.
S63 We replaced the instrument panel, but the fuel gauge is not working.
And the engine check lamp ignited.
Is it impossible if you don't code it?
help me!!
Old Oct 11, 2019 | 08:42 AM
1bad540's Avatar
s550 Diamond white amg pano
good luck on that sheet.
Old Oct 14, 2019 | 01:42 AM
Popo Here's Avatar
2008 S550 4Matic
You simply replaced it with a cluster that's incompatible with your vehicle and data is missing so the check engine light. The cluster will need to be virginized and all data deleted then your vehicle's data programmed to it. Not a DIY type of repair per say.
Old Oct 20, 2019 | 10:06 PM
w221 s500
How do I initialize a cluster?
Old Oct 27, 2019 | 08:18 AM
Polar Bear's Avatar
W221 S600, W220 S55 AMG Kompressor, W124 300E, W140 S320, W210 E3204M W164 ML320 Bluetec
You have to remove the data that has already been programmed into the device from the car it was removed from, and then using Daimler diagnostic equipment teach it in to your vehicle, synchronize mileage, and perform SCN coding.
If you do not have specific equipment to remove the programming already in place from the donor vehicle, it cannot be done. You can send it off to have it done and it would appear to the diagnostic equipment at the dealer as a new one, but you would need to find a dealer or independent that would SCN code it for you.
Old Dec 4, 2019 | 01:26 AM
antiguangenius's Avatar
2008 S550 4Matic, 2007 GL450, 2008 C300, 2018 GLE63 AMG
I did this, NO SCN needed, just zero milage and drive authorization thats it, if SCN will lose AMG functions,...
