"Power Steering Malfunction" light on
Old Oct 11, 2019 | 03:27 PM
Ninamashr's Avatar
2010 S550 Black on Black
I have a 2010 w221 with the electric power steering pump system. On the 1st cool day of the year I was driving my car and a big red " Power Steering Malfunction - See operators manual " warning comes up on my dash and the steering becomes really hard. I pulled off to the side, turned the car off, checked the power steering fluid level it was ok, restarted the car and it went away. I drove for another 30 miles and it happened again. Luckly I have a scanner, iCarsoft MBII, in my car, scanned the power steering module and it gave me a code: "C220D... internal fault in control unit". After researching I can't find that code anywhere and I also haven't been able to locate a picture of a power steering control unit. Does it even have one? Maybe it's on the electric power steering pump? I was able to locate a "Steering wheel" control unit behind the steering wheel, but no "power steering" control unit anywhere. Does anyone know?
Old Oct 11, 2019 | 04:07 PM
konigstiger's Avatar
'71 Pinto
Check the wiring harness @ steering pump for oil penetration due to internal leakage. If fine, best to pull codes using Xentry (MB diagnostics).
Old Oct 14, 2019 | 10:44 AM
Ninamashr's Avatar
Thank you Konigstiger, I did not see any leakage, I will check Xentry.
