AutoTalent | RennTech Ecu + Brakes + Spoiler For Mercedes-benz S 550 V8 BiTurbo
SPONSOR
![](https://cimg4.ibsrv.net/gimg/www.mbworld.org-vbulletin/1024x153/e3h3wk5_1abcfc2abb0ad1bcfe01742da6c811693ce01e2b_7f416b71423a35e1f25fcd5108130cecf2e0a5cd_c07c2519b7319a7502a5ff07720821f06fbbc6f2_4673d190331246_b417c1caf90c5712ec4cdc350ed1e79edf78af97.png)
![](https://cimg5.ibsrv.net/gimg/www.mbworld.org-vbulletin/1024x148/7vvm3jc_2a487a29958e257154f24ea3d382cdf0339a4083_35e1b34539289a661bbc69a4611261372dd082c8_fd90fc8225e22a7ad7bb53f7046a767bde8429e2_33f3f6336994_18b7528eddfac31022b56c2cacf321ad20b8b9a2.png)
Golan@AutoTalent.com
Renntech Performance Ecu Upgrade
Click HERE to order Performance Ecu!
Click HERE to order Performance Ecu +!
RennTech HHT (hand held tuner) allows you the unlimited ability to switch between tuned and stock ECU programming and requires no ECU removal. RennTech proprietary tuning module stores both the RennTech tuned file and your vehicles stock file. The module plugs directly into the OBD2 port and delivers the file you choose directly to the ECU. Programming takes only a few minutes and the vehicle can be reflashed at any time as many times as you wish. RennTech has been at the forefront of ECU tuning since electronic engine management started to show up in vehicles during the mid 1980's. RennTech experience, countless hours of in house research, development and exhaustive testing ensure that our proprietary ECU upgrade offers incredible performance gains and rock solid daily driver reliability. RennTech tuning software for Mercedes offers significant gains in horsepower and torque across the vehicles entire power band. By modifying ignition timing and throttle mapping, optimizing air/ fuel ratios, increasing the engines rev limiter and modifying boost mapping for turbo charged vehicles, RennTech performance software unleashes your Mercedes true potential.
Features
Long-lasting and driver reliability
Significant gains in horsepower
Increases the performance
Significant gains torque
Increasing the engine's rev limiter
Incredible performance gains
![](https://cimg2.ibsrv.net/gimg/www.mbworld.org-vbulletin/800x800/renntech_hht_001_531de3afd988472514d0b0c10c05929e1182c602.jpg)
![](https://cimg3.ibsrv.net/gimg/www.mbworld.org-vbulletin/800x800/renntech_hht_002_70eb6b9751bc6daf22032a8981ade2c6bc441623.jpg)
![](https://cimg4.ibsrv.net/gimg/www.mbworld.org-vbulletin/800x800/renntech_hht_hand_held_tuner_003_8a6ca151d3f9ccf232e8a11a30fc76ab72d4cf6a.jpg)
Renntech V3 Digital Suspension Lowering Module
Click HERE to order Performance Suspension Lowering Module!
The RennTech V3 Digital Lowering Module (DLM) is designed to work with all available Mercedes Airmatic or ABC (Hydraulic) Suspensions.The unit allows the user to have full control over all four corners of the vehicle’s suspension and adjust in 1mm increments. The DLM requires no splicing or soldering to the factory wiring harness. The RennTech harness utilizes the factory pins as to allow a completely reversible installation. The unit also supports speed-dependant lowering that allows the vehicle to return to its factory ride-height at a pre-set speed. This removes the need for the vehicle to be aligned after lowering. The user can maintain the factory longevity and still have the lowered look at low speeds. All RennTech DLMs are adjustable via USB using either Windows or Android OS.The software allows the user to adjust the ride-height at each corner in 1mm increments independently.The software also has three locations where the user can store pre-configured suspension setups for quick changes.
Features
Current Consumption: 30mA (60mA while plugged in to PC/Tablet)
Adjustment increments: 1mm
Maximum Lowering: Limited only by vehicle
Adjustment Methods: PC or Android (Tablet)
Size: 53mm x 73mm x 24mm
Weight: 1.2oz
![](https://cimg4.ibsrv.net/gimg/www.mbworld.org-vbulletin/800x800/32_221_1001_001_0e847fbcbd1572c23d20a6fce3bde5bde7dc89a0.jpg)
Renntech Performance Transmission Upgrade
Click HERE to order Performance Transmission Upgrade!
RennTech transmission upgrade consists of a complete transmission disassembly and inspection as well as a mechanical upgrade to the transmission clutch packs. This allows us the ability to maximize the amount of friction materials contained within the transmission and in turn, the amount of power which can be transmitted through each forward gear. During final assembly the transmission also receives all new gaskets, seals, o-rings as well as a new transmission pan filter. RennTech 722.9 Five speed Mercedes Transmissions increased engine performance it becomes necessary to further improve the drive line components, most importantly the transmission in order to ensure maximum power is transmitted to the drive wheels without transmission slippage. This can not be realized with software and only truly be accomplished by an internal mechanical upgrade to the transmission hardware. RennTech is the foremost authority on transmission upgrades and has done countless rebuild and upgrades for the most demanding dealers and clients for over 21 years. RennTech upgrade leads to improved shift response, shift timing, increased torque handling capabilities and greater drivability under extreme conditions without sacrificing around town comfort.
Features
Ability to maximize the amount of friction materials
Increased torque handling capabilities
Improves vehicles responsiveness
Increased engine performance
High quality material used
Improved shift response
Improved performance
Greater drivability
Shift timing
![](https://cimg1.ibsrv.net/gimg/www.mbworld.org-vbulletin/800x800/10_92054384f9c7d9353df10c2c601d7eb98043ec0c.jpg)
Renntech Aero Carbon Fiber Decklid Spoiler
Click HERE to order Decklid Spoiler!
RennTech is proud to introduce an all new rear decklid spoiler design for the Mercedes-Benz SL-Class. This highly integrated pre-preg carbon fiber spoiler compliments the sophisticated and refined SL-Class exterior design language. The spoiler is coated inside and out with an all new acrylic UV protection system. A second layer of UV protectant clear coating is also applied using traditional spray methods. RennTech is proud to introduce this sporty yet elegant rear deck lid spoiler for the SL-Class. The rear spoiler integrates seamlessly into the rear of the SL and offers a dramatic, unique appearance to the rear exterior. RennTechfull carbon fiber spoiler is manufactured from extremely high quality, prepreg carbon fiber and available in both matte or gloss finish.
Features
Stunning good looks of vehicles
High quality meterials used
Looking more aggressive
Carbon Fiber meterials
Design is perfect
Simple to install
Glossy Finish
Matte Finish
![](https://cimg2.ibsrv.net/gimg/www.mbworld.org-vbulletin/800x800/renntech_carbon_fiber_deck_lid_spoiler_230_sl_003_284006e1225f09c0cf58359852a51147c76abe64.jpg)
![](https://cimg4.ibsrv.net/gimg/www.mbworld.org-vbulletin/800x800/renntech_carbon_fiber_deck_lid_spoiler_230_sl_007_650deed46a94028ebf9f640aa11e432547f215ff.jpg)
![](https://cimg6.ibsrv.net/gimg/www.mbworld.org-vbulletin/800x800/renntech_carbon_fiber_deck_lid_spoiler_230_sl_001_266c1432b22b23cb75bc1588590a7c840136c446.jpg)
Renntech Suspension Rear Camber Bushing Kit
Click HERE to order Rear Camber Bushing Kit!
RennTech Rear Camber Bushing Kit maintains stability at high speed, ensures the vehicle tracks straight under heavy acceleration as well as properly positions the car's suspension under heavy cornering and braking loads. When used with our adjustable camber bushings, the high-quality aircraft grade materials used in the toe links kit result in a "total package" solution that improves handling without negatively impacting ride quality and comfort. The RennTech toe link kit also allows the possibility of fine adjustments to the suspension and of bump steering for additional stability and improved vehicle handling characteristics. Renntech fully adjustable rear camber bushing kit allows for a greater range of rear camber adjustment.
Features
High-quality material used
Improve performance
Stunning good looks
Design is perfect
Simple to install
![](https://cimg0.ibsrv.net/gimg/www.mbworld.org-vbulletin/800x800/rear_camber_bushings_kit_001_d952050d2067c69f1755905c5815e56c033bdf03.jpg)
Renntech Performance Brake
Click HERE to order Renntech Performance Brake Package 1!
Click HERE to order Renntech Performance Brake Package 4!
Click HERE to order Renntech Performance Rear Brake Package!
RennTech understands that brakes are one of the most important components of any performance car. Big brake upgrades are some of the most capable systems available at any price. Designed specifically to complement and control the mass of high-performance Mercedes and AMG cars, RennTech's big brake packages deliver consistent, real-world performance and look great behind your performance wheels. RennTech basic brake upgrade uses braided steel lines (front and rear) and high-performance brake pads (front) to deliver more consistent brake pedal feel and reduce fade compared to stock. RennTech philosophy has always been to produce products without compromise.
Features
RennTech performance eight (8) piston front brake calipers
Deliver more consistent brake pedal feel
Reduce fade compared to stock
High-performance brake pads
Long-lasting reliability
14.2” two-piece rear rotors
4 piston rear brake calipers
Braided steel lines
16.2” two piece front rotors
Motorsport brake fluid
![](https://cimg2.ibsrv.net/gimg/www.mbworld.org-vbulletin/800x800/renntech_brake_pkg_1_8648c4820141136882e9ade3da184f8ce7cf4758.jpg)
![](https://cimg4.ibsrv.net/gimg/www.mbworld.org-vbulletin/800x800/renntech_rear_brake_pkg_7e9eb785755b446ac3a5a59e55fc50e589ee5158.jpg)
How to Place Your Order:
Phone Domestic: (855) 973-2757 X 104
Phone International: (310) 231-7800 X 104
E-mail: online@autotalent.com
Website: www.AutoTalent.com
Payment:
Attachment 439933
Installations:
Feel free to visit us at our facility in Los Angeles, CA.
We install everything we sell.
19143 S. Hamilton Ave
Gardena, CA 90248
Shipping:
All orders are shipped via FedEx, UPS, USPS and Pilot.
International, Hawaii and Alaska customers: Please contact us for the best quote possible.
Hours of Operation:
Monday through Friday: 10AM-7PM Pacific Time
Saturday: By appointment only
