DPF sensor
Old Nov 17, 2019 | 06:05 PM
C.zaharia247's Avatar
Mercedes Benz S-Class W221
DPF sensor update
Hello guys!
My car goes in to limp mode a few minutes after starting it, even imediatly if i floor it. If i stop the car then restart it it works fine then again it goes in limp mode.
The star says Particle filter defective, probable cause DPF pressure sensor.
I would want to know if the sensor is found under the hood like in the pic attatched or under the car, cause i would like to change it myself.
Also i would like to know if the part number is corect A0061539528
Vin number is: WDD2211261A399355
I can't seem to find an original part, i have found some made by Bosch and other manufactuers, will it work as the original and will i be able to delete the error?
thank you in advance!
Old Nov 17, 2019 | 08:10 PM
artim808's Avatar
2012 S350 Bluetec 4MATIC; 2011 ML350; 2005 C230k;
What's the error code you have? The part number is correct but old. Here is new part number: A6429050100
Old Nov 18, 2019 | 04:13 AM
Thank you very much.
I think the code is 129700
Old Nov 18, 2019 | 10:41 AM
artim808's Avatar
Try to replace DPF pressure sensor under the hood. See attached PDF how to replace it.
Old Nov 18, 2019 | 04:01 PM
Will do.
Is the heat shield held in place by some bolt or i just have to pull it upwords?
Old Dec 4, 2019 | 05:03 AM
Changed dpf pressure sensor
I have changed the dpf pressure senssor woth one made by Bosch. At first it allowed me to clear all fault codes, all clear and good. Whent for a test drive accelerated with kickdown it went in limp mode without check engine. The same error shows up, Dpf filter deffective, probable cause Dpf pressure sensor.
i must say that the car only goes in limp mode on hard acceleratioms. If i accelerate slowly it drives normal without problems for any distance.
any ideas anyone?
Old Nov 25, 2021 | 03:35 AM
drifter17a's Avatar
mercedes
Originally Posted by C.zaharia247
Hello guys!
what software is this please?
Old Nov 25, 2021 | 12:54 PM
BOTUS's Avatar
S500
that is the dealer STAR / XENTRY stuff - way more comprehensive and powerful than 5k's worth of snap on kit... (but only works on a Mercedes vehicle - it comes with idiot guides) if you own a few Mercs or keeping one longer than 18 month check/contact this guy here - he'll help u get set up with own system - it will save you thousands and let you do stuff you want to but can't afford
https://mbworld.org/forums/s-class-w...-software.html
