Considering 2012 S550
Old Mar 1, 2020 | 10:22 AM
johnlk25's Avatar
2016 E400 4Matic
I’m considering purchasing a 12 S550. It has P2, Driver Assistance Package, Sport Package, Pano, and 68k miles. Asking $21,995. The car fax shows that it’s had the intake manifold gasket replaced twice, the camshaft seal replaced once and the front shock absorbers replaced.
Is this anything that I need to be overly concerned about? I’ve never owned a S class before, only C and E classes.
Old Mar 1, 2020 | 05:29 PM
tx170754's Avatar
S560/SL550/LS460/Q70L 5.6 AWD
Well, that tells you what to expect in the long/short term, the question is are you prepared ($$$) for it ?
Old Mar 2, 2020 | 09:50 AM
JDowney's Avatar
2012 Mercedes-Benz S350 BlueTEC 2013 ML350 BlueTEC
Hi,
Ensure that there is no Oil Leak from the oil cooler gasket. It is a $50 gasket, but it costs thousands to install...
Jeff
Old Mar 2, 2020 | 10:44 PM
MBCO's Avatar
2015 SL550 & 2012 S550 4matic
A frequent comment surrounds the interior. Driver arm rest and console begins to pucker. Common on southern cars. Not as common on designo upgraded leathers and s600 models. Mechanical these cars are solid given maintenance schedule completely adhered. You will appreciate the higher build qualities and extra room in sclass over e series. Good luck with your purchase.
