722.9 fluid change question
Old Mar 26, 2020 | 07:50 PM
Will Hunt's Avatar
2008 s550
Can you use Valvoline max life multi vehicle aft and would the harbor freight multi use transfer pump work for filling with adapter?
https://www.harborfreight.com/multi-...+transfer+pump
Old Mar 29, 2020 | 12:15 AM
lkchris's Avatar
'10 CL550, '12 GL550
Fluid must meet Mercedes specification and say so on the bottle.
Old Mar 29, 2020 | 06:23 AM
Gazwould's Avatar
S204 C250 CDI Sport
7G+ gearbox ?
Old Mar 29, 2020 | 08:30 AM
chassis's Avatar
2017 GLE350 4MATIC
As lkchris mentioned, the fluid needs to meet M-B specs. The pump is not critical. Are you aware that filling the 7G-Tronic requires achieving operating temperature, and filling to overflow? This is not the same as changing engine oil.
Old Mar 29, 2020 | 08:35 PM
artim808's Avatar
2012 S350 Bluetec 4MATIC; 2011 ML350; 2005 C230k;
I have used same pump several times in the past on 722.9 and it worked well with proper adapter.
Old Mar 30, 2020 | 04:12 PM
Will Hunt's Avatar
2008 s550
08 s550 4matic
Old Mar 31, 2020 | 01:17 PM
artim808's Avatar
You can use any fluid from this list:
https://bevo.mercedes-benz.com/bevol...236.14_en.html
