Alternator not charging
Old Aug 13, 2020 | 08:50 AM
joseluu's Avatar
W221 S500 2010
Hi guys,
After fixing the cooling system, the power steering and the ABC suspension are OK.
Now, I have a problem with the alternator not charging. DAS says:
CODE 1337: Alternator serial interface.
Nothing else so far.
Any ideas? (What a summer!)
(published also on sister forums)
Old Aug 13, 2020 | 11:04 AM
Minh's Avatar
S350 2008
Your car having problem with alternator, you might change alternator regulator and if it not fix then you need to change a whole alternator.
Old Aug 14, 2020 | 12:00 PM
joseluu's Avatar
W221 S500 2010
Here are the screens from Xentry. A bit strange, aren’t they?
Old Aug 15, 2020 | 10:10 AM
Minh's Avatar
S350 2008
Replace alternator regulator first, if the isue not fix then you need to replace alternator.
