2007 s550 starter battery
Old Aug 23, 2020 | 07:58 PM
gasguzzle's Avatar
2007 s550
Hello, I have a 2007 s550 I need to get a new starter battery possibly. I have read the manual and it doesn't say I need to disconnect the battery in trunk when replacing the starter battery but I have read conflicting info saying I need to. Which way is it. I have a battery charger would it be safe to charge it I assume I would need to disconnect the negative first.? When I went to start it it was very sluggish and didn't start so I jumped it. Looked like all other electronics worked at the time (didn't test everything but dash lit up. Whats the chances of it being the trunk battery. I tested the starter battery with a multi meter. Asking because this is the first time I've needed to change a battery on this car.
Edit
Old Aug 25, 2020 | 12:34 PM
gasguzzle's Avatar
2007 s550
No replies? I fixed it myself!
Old Aug 25, 2020 | 09:01 PM
jaGTAR KAHLON's Avatar
2004 c230k
So did you figure it out? Because I would love to know. I changed both batteries, yeah I still have to jump in order to start
Old Aug 25, 2020 | 09:03 PM
2004 c230k
So did you figure it out? Because I would love tozz know. I changed both batteries, yeah I still have to jump in order to start
Old Aug 26, 2020 | 08:20 AM
tx170754's Avatar
S560/SL550/LS460/Q70L 5.6 AWD
The battery under the hood could be replaced without disconnecting the battery in the trunk.
Old Aug 26, 2020 | 08:39 AM
BOTUS's Avatar
S500
what I never tested but I'm sure may kill something.... if you touch either lead against the wrong place as you take a battery off (or leave to them to rest on something without thinking) whilst the other battery is still connected, something should go bang ?
and on this car could set you back 4k I expect that was an intentional side effect of the design
Old Aug 26, 2020 | 11:39 AM
gasguzzle's Avatar
2007 s550
It was just my starter battery that was dead. I jumped from another car to get it started. I also disconnected the battery in the trunk.
Old Aug 26, 2020 | 08:49 PM
tx170754's Avatar
I did changed it without disconnecting the trunk battery without any problems.
Old Aug 27, 2020 | 12:30 PM
YCHU's Avatar
2008 S550, 2004 G500, 2020 Cayenne
I don't know what's in the service manual, but MB Roadside Assistance came to my house and replaced the starter battery without even going near the trunk.
Old Aug 28, 2020 | 05:36 PM
gasguzzle's Avatar
2007 s550
I was going to have MB roadside come out. It was Sunday, I called 3 times, first person said tech will call me and come out nothing so I called again 20 min later the 2nd and 3rd ( I didn't believe no one thats why I called 3 times) person said being Sunday parts at dealers were closed and no one had a battery. So I woke up Monday and did it myself. Roadside would of came out to tow or jump but thats not what I needed.
I didnt take a chance so I disconndisconnected the trunk battery.
