How can I remove this paint
Old Aug 27, 2020 | 06:00 PM
DavidG63's Avatar
2012 Mercedes-Benz E350
Is there some sort of way I can undo this paint job to the original aluminum look without having to repaint the wheels? Thanks
Old Aug 29, 2020 | 11:29 AM
DaleB's Avatar
Veteran: Army
2007 S600
Do you have any idea what type of paint it is? Some of those wheel paints are peel-able, others would require solvent or stripping down to the metal. There's no way to tell what it will take to remove it unless you know what was done.
Old Aug 29, 2020 | 02:41 PM
jbarhorst's Avatar
2018 S450 4Matic, 2020 GLE450 4Matic, 2010 S550 4Matic(sold), 2012 ML350 4Matic(sold)
If they did the paint job properly, the original paint will be sanded to get proper adhesion with the new paint.
As DaleB said, some are actually peelable sprays - what does it feel like with your fingernail?
Does it feel like paint or a flexible coating?
Old Mar 18, 2024 | 09:58 AM
Petep's Avatar
2023 EQS 450 4-Matic Sedan
Looks like powder coating
Powder coating involves sandblasting the item down to its bare metal state and baking on a new finish using the powder coating color of your choice. If those wheels are powder coated, it isn't coming off unless you repeat the process. Because of the sand blasting prep, you can't really restore the original finish on those wheels, although you will discover, there are dozens of powder coating finishes to choose from.
