Heater vents question
Old Sep 10, 2020 | 10:16 AM
Ninamashr's Avatar
2010 S550 Black on Black
Today was the first day i've had to use my heater. It was 55 outside and I set the temp to 78, the climate system set to automatic. I noticed that no heat came out of the center dash vents (silver ones). Is this normal? The heat only came out of the side vents and a little bit under the front window. Can somebody confirm if when thier heater is on that they get heat out of the two center vents?
Old Sep 10, 2020 | 10:29 AM
BOTUS's Avatar
S500
in auto the car works out which vents to use based on 9 interior sensor pretending they have a clue....
you can have auto vent or not
best on manual vent, auto temp, switch the vents to all equal with 3 large arrows, set the fan at 3 and temp at 70 then you never need touch them again in your life
buried in other settings you can adjust the foot well higher or lower than the others
Old Sep 10, 2020 | 12:23 PM
Ninamashr's Avatar
Thank you so much, i'll try that!
Old Sep 10, 2020 | 01:05 PM
BOTUS's Avatar
S500
my left vent (passenger side on UK vehicles) sometimes forgets to work, I manually persuade and it wakes up and works for a few weeks. In diagnostic tool I found a re calibrate all the vents (not sure it was a great idea) also seems to say you can with diagnostics customise vents / flow rates to suite customer request
mine used to have more air flow to the face level vents then after a new AC condenser OR after a software update, I have less air flow and its really irritating ….
Old Dec 20, 2021 | 04:22 PM
Ninamashr's Avatar
So Winter is back and I need an answer after all. I have a scan tool that checks the live data and I could see that when i raise the temperature to about 79-80 degrees the center dash vent flaps were open only 10-12% and the input coming from the control unit was also the same 10-12% so it makes me think that the center dash vents do not open up to let hot air into the cabin. Can somebody just set thier climate control to Auto and raise the temperature to 80 or so and let me know if hot air comes out of the center dash vents or not? I'd appreciate it.
Old Dec 21, 2021 | 05:37 AM
BOTUS's Avatar
S500
there are manual vent closure / flow restriction turn knobs on each individual vent. If these are OFF nothing will come out
then we get to a question do you mean NO heat or NO airflow ? a cheap valve near the wipers wears out and stops heat working correctly, regardless of what you do in the car.
then we get to the display at the bottom of the screen....
in the middle AC you can go in here and find more confusion, like set it to control the rear (if you have it), make the rear follow the front etc. And then airflow features diffuse / focused / or whatever. The idea in AUTO with diffuse the air wafts quietly around. Focus get more air out of the vents. This setting makes the amount out of the centre vents change
If you put the fan on 7 and then go to the auto words and twiddle the comand knob you can switch air flow between three locations feet / screen / face - with a little arrow for low air flow or a big arrow for lots of airflow
Old Dec 21, 2021 | 05:57 AM
nath_h's Avatar
2008 CL550, 2022 EQB 300, 2023 EQS 450 4Matic
Can you elaborate on what the valve is near the wipers? I've had my car a few months, and it is now getting cold. I've noticed that I have to set my heat to about 80 degrees in order for the cabin to stay decently warm. I don't recall any other car I've had needing to set the heat at anything other than a 'normal' 71 or so. Wondering if my problem is the valve you mentioned? If anyone else has input, please let me know.
Old Dec 21, 2021 | 09:25 AM
BOTUS's Avatar
S500
its DIY ish
170 VALVE
CHANGE-OVER VALVE 001 A 23 083 000 84 - $50.90
Old Dec 21, 2021 | 12:04 PM
EasyPhil's Avatar
2007 S550 4Matic 2013 S550 Base
All vents in my 2007 deliver heat on a day like today where the temperature shows 37 degrees F. My car is set for 75 degrees, all year.
