2007 S550 W221 Front left wheel noisy for the first 20 mins of driving
Old Dec 2, 2020 | 05:47 PM
Fabonation's Avatar
S550
Hello, I have a 2007 S550 that is noisy near the front left wheel. It sounds like bad a suspension, struts, etc...It makes noise no matter the size of the bumps on the road. Its worst going over speed bumps (slowly). The car recently passed inspection and the inspector couldn't find anything loose.. ball joint, tie rod, etc.
After driving for about 20 mins the noise goes completely away. The ride is very smooth and no noise from the left wheel. If I turn the car off for more than about an hour then ill have to drive another 20 mins before the ride is smooth and the noise is gone. I can't figure out what the problem can be. I dont notice any sagging when the car is off or on.. Please help with any advice.
Old Dec 2, 2020 | 06:29 PM
kbob999's Avatar
'20 X5 M50i; '17 Ram 3500; Golf Cart; Bikes; Scooters
Some questions that will help find the cause.
Is this a 4matic or rear drive?
Is this an airmatic or ABC suspension?
Does it only make the noise on rough surfaces, or on smooth also?
Old Dec 2, 2020 | 07:00 PM
Fabonation's Avatar
S550
The car is rear wheel drive.
I believe it's airmatic because there is an air suspension button on my dashboard. When I press it I notice the car will raise up.
It make a noise on any surface for about the first 20 mins. Smooth surfaces, the noise is more softer. Rough surfaces, the noise is louder.
Old Dec 3, 2020 | 10:11 AM
kbob999's Avatar
Ok, that narrows down the possible causes.
Next - does the sound happen while standing still, or only while moving? This has a big influence on the possible cause, as it would be engine related, or wheel/suspension related..
Could you describe the sound? Is it a click, or screech, or rattle, or thumping?
Old Dec 3, 2020 | 10:39 AM
Fabonation's Avatar
S550
It only happens when driving. It's more like a thumping sound. Dup dup....
Old Dec 3, 2020 | 05:06 PM
kbob999's Avatar
This one sounds tough to pinpoint. I'm going to be guessing myself, as noises are the hardest to solve without hearing them.
Sounds like something that goes away when warm, and only makes noise when the car is moving. That would say it is something to do with motion, like the brakes, or bearings, possibly the sway bar. Maybe a rag stuck in the brake rotor?
A long shot option would be a plastic panel, something with the airmatic suspension, or the engine, possibly a bubble in the tire, or loose wheel. These would likely remain when warm, not go away.
Does it speed up when you speed up, or remain the same frequency?
Does the noise remain the same when gentle braking, or coasting, or accelerating?
What about turning to the left or right?
We'll figure this out eventually.
