New tires and now a dead battery and leaking coolant
took my 2009 S550 in for new rear tires today, and on the way home I got a message “start the engine within 3 minutes or COMAND will shut off”. Made it home and let the car idle for about 20 minutes then shut off the engine and tried to restart with no luck. I also noticed some dripping liquid in the front drivers side, originally I thought it was the usual condensation from the AC, but dropped a paper towel on it to find it was a blue liquid (coolant I believe?).
Now I honestly don’t know how replacing the rear tires could cause either of these problems, but the battery is less than a year old, and the alternator is about 2. Is this just a very strange coincidence, or could something have been done wrong with the tire replacement?
Lets start guessing how, Did they blast your radio for some nice music while they changed your tires?
Any reason for them to open the hood? did you ask for any fluid top ups?
similar error, he got his battery and alternator checked.
https://mbworld.org/forums/e-class-w...-included.html
If you say the battery is fine, then the battery charging may be intermittent (e.g. Alternator issue).
as far as going under the hood, doesn’t the battery have to be disconnected because of the airmatic suspension? Or did I make that up... I might have.
the car did sit for 4 days without being run, but that shouldn’t be an issue with a relatively new battery and alternator.
I dont know about the specifics of the airmatic suspension
The leaking 'blue' fluid on the other hand... what color is your coolant in the reservoir
*Your car seems to have 2 batteries, one in the trunk and one in the engine bay. hopefully someone experienced can offer you advice
