2006 S350L features
How do the lumbar support work and
Night vision how does this work, SPECIALLY on the S350L
then you get the operator manual all 568 page (all English!!!) and take a few months to decipher what it says (you can find online if its not with the car)
the lumbar will likely be broken, dead module, popped cushion, popped air line or dead PSE in the boot. Quite likely all 4 normal failure modes on a car that age
night vison steals 2 good headlamp bulbs (so you can't see anything at night) and replaces with two IR bulbs that vaguely see 3mm further up the road and gives a silly picture hidden behind the steering wheel that you can't safely use. You can't at anything over 25mph safely look at both and interpret the differing views successfully. Its a crazy dangerous idea that stole real light where you needed it... it only comes on with the headlight on at night.... the switch is by the key NEVER use sit except to show others how pointless it is (much like the TV)
