Fuel stop nightmare
The fuel gauge is working, no codes (yet), engine is smooth, and the car rides like normal. I was just having thoughts of my next "A" service at the dealer turning into a new fuel tank and associated electronic components replace due to driver stupidity.
The only damage I see could be at the end of the filler and you said it was a little harder to put the cap on. If the edge of the filler got bent enough you could have a seal leak, which could trigger the CEL but if you drive a day without the light you should be fine other than tighter than normal cap.
