WHEEL
Old Sep 29, 2021 | 10:21 AM
natcahd's Avatar
Veteran: Air Force
2023 S580 (Current) 2011 S550
WHEEL
All,
Where is the best place to get a replacement wheel for w221(20 AMG)? Online or local (ATL Area). Damn potholes.
Hd
Old Sep 29, 2021 | 03:59 PM
vettebk's Avatar
2007 S600, 2007 Chrysler 300 SRT8, 2000 C5 Corvette, 2017 Mustang GT, 2023 300C, and a 2019 Lincoln
I had a similar problem but on a 19 inch wheel. Tried used websites and everyone claimed to have one but when ordered it came back as a bent wheel. I didn't need another bent wheel. I looked at aftermarket wheels but couldn't match it to OEM shape and spokesize. Had to break down and call the dealer. Dealer said no problem at all, just need $840 and a core charge of $100 against my old bent wheel. I told him I just wanted a regular wheel not the gold covered special wheel. He said that was for a regular wheel. I paid it. No choice. Pure robbery.
Now I will tell you I run all of my tires at 38 pounds of cold pressure now to avoid bending the wheel in the pot holes.
Good luck.
Old Sep 29, 2021 | 04:21 PM
natcahd's Avatar
Veteran: Air Force
Vette,
Thank you...That is crazy!
HD
Old Sep 29, 2021 | 06:24 PM
WHPH28's Avatar
Depends on the weather
Which 20" wheel do you need?
Edit: I am ssuming the 20" in your profile pic?
Old Sep 29, 2021 | 07:02 PM
natcahd's Avatar
Veteran: Air Force
WHPH,
Front, yes profile pic.
Old Sep 30, 2021 | 10:21 AM
Arrie's Avatar
Originally Posted by natcahd
All,
Hd
Wheels can be straightened and even welded.
I had two wheel on my E550 that I had straightened by a local guy. $100 each. No welding though.
Old Sep 30, 2021 | 10:30 AM
natcahd's Avatar
Veteran: Air Force
Arrie,
I will make some inquiries. Have you had problems with the repaired rims?
Old Oct 1, 2021 | 03:00 PM
WHPH28's Avatar
I see 2 sets of 4 on facebook marketplace for $800 and $855...location is PA though for both sets.
Old Oct 1, 2021 | 08:10 PM
natcahd's Avatar
Veteran: Air Force
WHPH,
Thanks ill look.
Old Oct 3, 2021 | 06:43 PM
Arrie's Avatar
Arrie,
No problems at all with repaired rims.
Old Oct 3, 2021 | 07:08 PM
natcahd's Avatar
Veteran: Air Force
Arrie,
Thank you
Hd
Old Oct 14, 2021 | 10:00 AM
natcahd's Avatar
Veteran: Air Force
UPDATE: I I had two rims repaired (cracks welded and rims straightened). Went to discount tire to have tires replaced under their warranty. I watched as they balanced the wheels with a little nervousness. It appears the rim repair was done well as there were no problems with the balancing. The car rides as well as before. At 175 per wheel (would have been 125 but crack weld was extra) turns out to be a good deal so far. Thanks to all who weighed in.
Hd
