Random question about rear doors
Old Nov 20, 2021 | 03:33 PM
clb0099's Avatar
‘16 Mercedes GLE450 amg,’15 Mercedes gla, coupe,’07 Mercedes w221,’12 Audi A
So I decided to do a mod in my car that brings it update in my eyes. All the newer Mercedes vehicles have the led lighting strips on the dashboard and all the door panels. The wiring isn’t bad until you get to the rear doors. The rear doors don’t have have a wiring harness that has actually wires running through it. Instead it has a harness that comes from the door jamb that plugs into the actually door itself. So I ended up buying a step drill bit and also some wiring loom so that I could make it look as factory as I can. With that said before I start drilling into the jam of the door should I be considered of any objects that be inside the door itself? The actual hole won’t wider than a nickel coin. Once I am able to drill these holes then the rest is easy. This is a DIY but it takes time and patience. My car is sitting as I wait for the ABS pump module back from being repaired so I figured I would do this mod as well adding wheels spacers all the way around. 15mm front and 20mm rear. Also decided to paint my brake calipers seal grey. Figured it would give a nice contrast.
Very hard to really see the Led strip but if you look at the door wood trim its running along it. As I tried to make it look as oem as possible. I used silicone to keep it in place as the kit is from Amazon and was very well made. The led lightning system comes with remote but also you download an app on your phone to control it. Once I am done I will post more pictures.
Old Nov 22, 2021 | 02:26 AM
Senecat's Avatar
1983 Nissan Shltbox
Drill it. Be careful. You'll be fine.
Old Nov 22, 2021 | 06:00 PM
clb0099's Avatar
Thank you for the response. Hopefully this week I can complete this project
