W221 Flex disc
Could someone please assist me with the correct part # for rear and front flex discs on S550 4matic 2010...
I just went thru this and most of my vibration went away with engine and transmission mount replacement but some of it remained. The dealer pointed out flex discs having some cracking on them and I had them changed and this seemed to really get rest of vibration go away. The old discs did not look that bad at all though. They had some cracking (dry rot) but it was not bad. I just went by their recommendation. Only negative now is the noise I get that I hope is the center bearing and not the tranny itself. That is in another thread but for vibration the flex discs had something to do with it in my car so as it is the lowest cost (DIY) work to do for vibration troubleshooting replacing them rubber parts in a 10+ years old car is not a bad idea at all.
I have a gift card I could use on amazon, anyone know if this part fits...
Febi Propeller Shaft Flex Disc Kit https://www.amazon.com/dp/B000P4S09E/ref=cm_sw_r_cp_api_i_VK4PYE3076N99R9VDS7C
Febi Propeller Shaft Flex Disc Kit https://www.amazon.com/dp/B000P4S09E...3076N99R9VDS7C
