Back Up Camera Only Works Sometimes
Old Apr 10, 2022 | 07:56 PM
s550hollywood's Avatar
2013 s550
2013 Mercedes W221 S550 Backup camera not always working. Here's how I found the problem and fixed it for free.
If you see this sometimes when shifting into reverse, I know what the problem is and its an easy fix. Do not take to the dealer until you first try this.
If you don't see the images behind your car in reverse sometimes and sometimes you do, it very likely a wire in the trunk is being slowly cut. When you do not see the image, but you do see the colored guidelines on the display, this video will help you determine if the wire is being cut. It's due to the wire being held by a plastic grommet in the trunk which is slowly cutting the wire. That's why it shows a picture sometimes and sometimes it doesn't. I made a before video and an after video.
Before - Locating the wire to see if its cut
After finding the cut wire and easily fixing it for free
