Wheel Sensor Missing message
Old Apr 16, 2022 | 03:59 PM
RichDMB's Avatar
2008 S550
After driving for 20+ minutes this message comes on. I assume the sensor is just dead and needs to be replaced. New tires were put on recently. Does the driver side rear wheel need to be removed to replace this?
Old Apr 16, 2022 | 10:11 PM
Senecat's Avatar
1983 Nissan Shltbox
Yup. You lost a TPMS sensor. It's inside the wheel and transmits pressure data. No big deal.
Old Apr 18, 2022 | 07:56 AM
doni01's Avatar
2013 S550 4MATIC
Yes your wheel/tire needs to be removed. Purchase a new sensor and bring the car to a tire shop. They should swap it in about 10 min for you.
Old Apr 18, 2022 | 10:36 AM
konigstiger's Avatar
'71 Pinto
Have shop revisit at no cost.
Old Apr 18, 2022 | 11:31 AM
Long2757's Avatar
2007 S550 AMG Sport
My car recently did this. I ordered a replacement TPMS sensor from Rock Auto and had it installed for $10 at my local Discount Tire store.
The salesman at the tire store said he also stocks these sensors, but I don't know if his price was less than what I paid to purchase the sensor.
They don't last forever. They have an internal battery that fails with age.
I used this VDO sensor and it works perfectly: More Information for VDO / CONTINENTAL SE58001 (rockauto.com)
Old Apr 18, 2022 | 11:36 AM
RichDMB's Avatar
2008 S550
On Rockauto I saw the sensors range from like $20 up to $80, how much did you spend?
Old Apr 18, 2022 | 11:41 AM
'71 Pinto
When you had tires replaced did they replace sensors or simply move old to new tires? 'Normally' a shop would install new sensors if this is the case new sensor may need replacement or system needs to be re-calibrated this is why I suggested have them revisit - you're call.
Long2757's Avatar
2007 S550 AMG Sport
It was $27 plus shipping. VDO is a manufacturer of OEM parts for many car companies, so I chose that brand as they are known quality.
Also after they installed it, I jumped on the highway for about 10-15 minutes and the car then turned the light off and I was able to go into the system messages and tire pressure settings and tell it to use the new values as standard. Been a month now and no more tire light and I've put close to 2000 miles on it since then running out to CA and back.
Old Apr 18, 2022 | 11:43 AM
Long2757's Avatar
2007 S550 AMG Sport
On my car when tires were installed, they didn't replace the sensors as they are quite pricey in addition to the tires. They told me they remove them, put a new o-ring/seal in the stem where it mounts to the wheel to prevent leak, and then re-assemble. The tires get replaced but the sensors just get a new seal otherwise you'd be adding an additional $200-300 on top of tire cost.
Old Apr 18, 2022 | 11:48 AM
'71 Pinto
OP is talking 14 years a shop should at least ask if you want sensors replaced given time elapsed & internal sensor battery age.
