Hydrolock
Old Apr 24, 2022 | 05:36 AM
2011S550w221's Avatar
2011 S550
Hydrolock
So I found bent piston rod
replaced
put EVERYTHING back on
engine doesn’t crack
display on
radio works
question- what do I do to get motor to crank?
lmk your thoughts
thx
richard
Old Apr 24, 2022 | 09:43 AM
chassis's Avatar
2017 GLE350 4MATIC
Who replaced the rod? Do you have XENTRY?
Old Apr 24, 2022 | 12:17 PM
BOTUS's Avatar
S500
its extremely unlikely when you bend a rod that you didn't trash the block (and the crank won't like it either)
AMG motors its normal to snag a rod and trash the engine (its a design feature), animals out there do a cast iron liner mod, that real animals do on one pot only - then clear the car quick smart
what bent the rod nasty map and ragging a stone cold engine (that's the usual driver) or leaking injectors etc.?
Old Apr 24, 2022 | 02:00 PM
2011 S550
Hydrolock
I had a mechanic do it
took 2 months little by little
no I don’t have XENTRY
I will look but where can I get a XENTRY?
thx
Old Apr 24, 2022 | 02:13 PM
chassis's Avatar
2017 GLE350 4MATIC
What caused the rod failure?
Message user @BenzNinja
Old Apr 24, 2022 | 03:43 PM
2011 S550
Hydrolock
Water coming in from front intake to manifold
Old Apr 24, 2022 | 05:23 PM
Senecat's Avatar
1983 Nissan Shltbox
Well at least the radio works.
Old Apr 24, 2022 | 08:36 PM
chassis's Avatar
2017 GLE350 4MATIC
You need XENTRY, or at least your mechanic does. If the mechanic reassembled the engine, can't get it to start, and doesn't have XENTRY, it's probably time to find a new mechanic.
