I need some help folks!
Old May 12, 2022 | 06:37 PM
Jael's Avatar
2013 Mercedes-Benz S550 Sport Package
Hi. Before acquisition of my car I noted that I had no washer fluid. I checked with seller and confirmed a faulty washer pump. However, I discovered via research that gromets may be needed as well.
In addition, I’ve attached pictures of what I found. Anyone with expertise or knowledge on how I can go about this please help with what you know. Thank you.
Regards,
Jael
Pic 1
Pic 2
Old May 13, 2022 | 02:13 PM
nath_h's Avatar
2008 CL550, 2022 EQB 300, 2023 EQS 450 4Matic
My tank was leaking also...might need that too.
Old May 13, 2022 | 02:23 PM
BOTUS's Avatar
S500
can't be sure but looks like you snapped something off somewhere....
Old May 13, 2022 | 02:26 PM
BOTUS's Avatar
S500
don't buy genuine spares for this part - hideous cost and specially engineered to leak by and seize the pump motor around 7 to 10 year mark - buy a copy that will just work faultlessly for 25 years at 20% of the cost
Old May 13, 2022 | 05:30 PM
WHPH28's Avatar
Depends on the weather
20.00 on ebay, but plenty of places with them for under 40.00.
Old May 14, 2022 | 10:49 AM
Arrie's Avatar
Regards,
Jael
Pic 1
Pic 2
The first picture is the pump and this was also my first job with my car. Was bad at the time I bought the car. It cost $85 from the dealer with grommet, which you absolutely must have as the leak is from the worn out grommet in almost all cases. Tight fit thru the grommet is the only way pump is held in place. Vibration wears out the grommet leading to leak.
The second picture I do not recognize. Pump has only one connector and it does not look like connector for head light washer pump either.
Old May 14, 2022 | 01:57 PM
konigstiger's Avatar
'71 Pinto
Pic 2 is heated windshield hose/nozzles connection.
File Type: pdf
Old Nov 15, 2022 | 01:47 PM
Jael's Avatar
Thanks I looked it up. Part on the way.
Old Nov 15, 2022 | 01:49 PM
Jael's Avatar
[QUOTE=konigstiger;8563773]Pic 2 is heated windshield hose/nozzles connection.
Thanks a lot man. This helped a lot.
