Speed Sensor signals
Old May 20, 2022 | 02:58 PM
Blizare's Avatar
1990 300e
Attached are some signals from all 4 wheel speed sensors.
Do these look normal or should I replace them all?
Here I was simply driving from standstill to about 30mph
Old May 20, 2022 | 02:59 PM
Blizare's Avatar
1990 300e
Also as I'm watching the scanner they are all dropping to 0.0 every few seconds and then back up to a normal number....
Old May 21, 2022 | 05:51 AM
BOTUS's Avatar
S500
never looked at a trace
they were designed to fail around the 9 year mark - first symptom is the park brake being "strange", up to 6 months later the ESP light comes on in the instrument cluster
Old May 22, 2022 | 12:20 PM
MBCO's Avatar
2015 SL550 & 2012 S550 4matic
You might consider a remove and clean exercise on the sensors that attach to the wheel hub. I replaced both my front sensors when my light come on. Look for posts from Easy Phil on this board for his take on cleaning. Perhaps a dirty sensor is causing flat lines on your scan.
