Rear Differential Rebuild Possible?
Old Aug 4, 2022 | 09:48 PM
joeshannon095's Avatar
2018 S560, 2004 SL500, 2014 S550 (SOLD), 2012 S550 x2(SOLD), 2007 CL600 (SOLD), 2007 S600(SOLD)
I have a 2012 S550 RWD with about 123k miles on it. Since I've owned it, I have noticed a rumble from the differential while it is not under load. Basically accelerate to 90mph, release gas and coast until 65mph, and you will hear and somewhat feel a distinct rumble. Put the engine under load again and it disappears. My tech at work diagnosed the rear differential as the issue. Mercedes official solution is full replacement. I was curious if anyone has had luck having the rear differential rebuilt? I drove a 30k mile example to compare and there was none of the rumble or noise that is present on my car. Looking for a more economical route than a new diff, and used ones are a bit of a gamble.
Old Aug 5, 2022 | 11:38 AM
chassis's Avatar
2017 GLE350 4MATIC
Rumble = rubber mounts failed and typically are at one speed but not always.
Bearings are a growl or hum that varies with speed and throttle.
Gears are a whine at speed and varies with throttle, with specific speeds that are louder than others.
Which symptom(s) do you have? Look for a rebuilt unit. Rebuilding an axle yourself will be an unlikely project unless you are “in the business”.
Old Aug 5, 2022 | 12:41 PM
WRC-LVR's Avatar
2012 E350 Cabriolet now SOLD to my son
Op indicated rumble maybe the rubber mounts then? ? $ for parts and installation?
Old Aug 5, 2022 | 01:15 PM
BOTUS's Avatar
S500
I gather there's a dealer special tool to do the bushes otherwise 6hrs to pull it all apart - and its a common failure
Old Aug 5, 2022 | 06:42 PM
Thank you. I've been told its bearing related. They won't do a rebuild at the dealership, which I expected, so I was curious if anyone has had their diff rebuilt before or should I be looking for a replacement?
Old Aug 6, 2022 | 03:26 AM
BOTUS's Avatar
S500
not read anyone here, or on UK forum in last 5 year complain about their diff (and u have low miles for one of these to have that issue)
you have 4cv joints on the drive shafts and 2 wheel bearings that might make noises - but again unless you sat in a bath of salt shouldn't do it
- try swapping over the rear tyres - I have a car that makes what I thought was a bearing whine/ very light rumble - been about the same last 3 years.... But the guy doing the MOT last year (UK roadworthiness check) said, need to look at suspension bushes your left rear tyre is starting to have odd wear pattern - didn't believe him went to look and he's right - he went on to say he see's loads of vehicles and the idiots all go off and do wheel bearings, and come back moaning it never made the noise go..
Old Aug 6, 2022 | 02:01 PM
Appreciate the insight. I've already gone that route and it doesn't appear to be a bushing or wheel/tire issue. I don't think its a bearing either as its not the typical whine you get with a bad bearing. Its specifically at higher speeds when not under load. My shop foreman confirmed this without pulling apart the diff. I've found some replacements on eBay for reasonable prices so I may go that route as I have the tools and ability to swap it on my own. We'll see how this all goes. Its not a major issue, I'm just hyper sensitive about my car.
Old Aug 6, 2022 | 03:05 PM
chassis's Avatar
2017 GLE350 4MATIC
Replacement.
Old Aug 6, 2022 | 08:12 PM
Originally Posted by chassis
Replacement.
That seems to be the consensus. Need some help deciphering part #'s if you or anyone can help. The part # I was given by my parts department was 221350391480. I've been scouring ebay and have found a variety of differentials available for the 2012-13 S550 with the M278. All of them share the part # 2213503659. Obviously this does not match but its consistent across the ebay diffs I've found. I'll link an example below.
https://www.ebay.com/itm/16431223652...66ce%7Ciid%3A1
Old Aug 6, 2022 | 09:55 PM
chassis's Avatar
2017 GLE350 4MATIC
From memory the ratio is stamped in the axle housing. Maybe also the ring gear diameter. It's been a while since I was under my vehicle looking at the rear axle.
EPC the the gospel here. Crawl under your vehicle and take note of all markings. Then use EPC using your VIN and confirm the part number and gear ratio.
Old Aug 7, 2022 | 10:36 AM
konigstiger's Avatar
'71 Pinto
Provide VIN.
Old Aug 7, 2022 | 07:18 PM
Provide VIN.
WDDNG7DB3CA424184. Hello from Scottsdale!
Old Aug 8, 2022 | 11:17 AM
'71 Pinto
File Type: pdf
File Type: pdf
Old Aug 8, 2022 | 01:15 PM
drchpeteros's Avatar
e350 4matic wagon 2009
2009 E350 4matic wagon. My rear diff went around 90K. MB wanted to do a whole rebuilt diff for 4200 like you've been told. I found a shop in Buchanan, NY (a 2 hour trip for me) who specializes in this. Little Bear Auto (link below). They rebuilt mine for $1500. I'm now at 130K and no problems since. Not sure where you live but if anywhere within a few hours of them, it's worth it.
https://www.littlebearauto.com/
Old Feb 23, 2023 | 10:40 PM
lukacsmw's Avatar
CLK550
I need to do this - my rear differential is making a very loud road noise. My usual repair shop just told me it’s the differential and I need a new one. They said Mercedes wants $3300 for just the part, but they might be able to find a good used one for cheaper. They also said they used to rebuild them, but Mercedes locked out the part numbers, so you can’t even get the replacement parts to rebuild. However, it seems like reading this forum, people have been having success on a rebuild. Anyone have a recommendation on company in Northern Virginia that could do this?
Old Feb 23, 2023 | 11:03 PM
Try calling Little Bear in NY. Explain your situation and ask if he can get and sell you the parts and ship them to your rebuild guy. I remember he had a source for the parts that were not otherwise easy to get. It can't hurt to ask.
Old Feb 26, 2023 | 09:44 AM
JohnLane's Avatar
222 S-65
Bearings in the differential all have part numbers on them. Bearing supply shops will be able to supply bearings. Carrier bearings rarely fail. It will be bearings on the pinion shaft. I have done dozens of differential rebuilds. Once you have your head around how it works they are easy.
Old Feb 26, 2023 | 11:21 AM
And Konigstiger provided the part numbers in this thread up above.
Old Feb 26, 2023 | 05:18 PM
JohnLane's Avatar
222 S-65
No pics of bearings in that screenshot.
Mercedes part numbers will be different from the SKF part numbers on the bearings. Use the part number on the bearings when inquiring at a bearing shop. MB part numbers at MB. If OP is going to replace bearings a pinion seal will be needed.
