Wheel speed sensor destroyed
scanner showed no communication with the ABS/ESP module
Had the module repaired.
Scanner now showed front left sensor issue.
Took the sensor out to replace. It was almost half missing. As if it was grinding against the reluctor ring.
My theory is that the ring got swollen because of rust and destroyed the sensor. Does that sound possible?
It looks like the ring can’t be replaced. Am I right?
Only option is to replace the axle?
There seem to be super cheap axles available (like $100-200 cheap, rockauto type places). Should I steer clear?
I just want the car to be driveable so we can sell it for cheap.
Thanks in advance 👍
front sensors
https://nemigaparts.com/cat_spares/e...84/63w/54/663/
brakes
https://nemigaparts.com/cat_spares/e...221084/63w/42/
Interesting… so I’ll forget about the axle.
Anybody have a part # for the oil seal? I don’t see the part on the diagram.
How much of a pain is it to replace the bearings? I am worried this will be outside my DIY skill range 😆
you could get the bits, strip it down and take to a competent garage to swap the bearings - but they get funny as not much profit and can't vouch u assembled it right - it why getting to know them and taking other business to them helps u both out
On a scale of 1 to 10 where 1 is changing the oil and 10 is a full engine rebuild I'd give it a 4!
Trying to identify the seal. Anybody have a diagram?
I see the circlip and bearing but no seal 🤷♂️
Cheers!
I see a lot of places sell front hub assemblies. From the photos, it looks like the bearing is pre-pressed. That would solve the problem of pressing in the bearing.
It just seems to be that removing the hub assembly might be a huge PITA. Am I right?
just did some on my father's e class (w211), on this its swap out the whole hub - new one comes with bearings and seals in place - the labour to source seals and to knock them out, and fit new is probably more than a mega discount from your main parts guy
not sure on the 221 if the world works the same way, likely not as its the whole knuckle on a 4 x 4
