Squeaky when getting in and while driving.
Old Nov 10, 2022 | 06:11 PM
Bebe9803's Avatar
2008 Mercedes S550
If I push on front end it squeaks. When I get in omto sit down it does as well as while driving.
Not all the time. But a bit.
Is this the arm or ball joint?
Old Nov 10, 2022 | 11:18 PM
COUPCONNOISSEUR's Avatar
2010 CL550
does it sound like this? If so, it depends on whether your s class has 4matic or not. In my case(4matic) this squeak/chirping was caused by the failed ball joint built into the strut. On 4matic S/CL classes equipped with airmatic, the load bearing ball joint is built into the strut. On RWD models, the ball joint is built into the lower control arm.
Old Nov 10, 2022 | 11:25 PM
Bebe9803's Avatar
2008 Mercedes S550
Originally Posted by COUPCONNOISSEUR
does it sounds like this?
I'm pretty sure that's it
And if I push the front end down or sit it makes the same squeaky sound 😂
Old Nov 10, 2022 | 11:36 PM
2010 CL550
in my case, it was replacing the strut that fixed the squeak.
Old Nov 11, 2022 | 08:52 AM
EasyPhil's Avatar
2007 S550 4Matic 2013 S550 Base
You actually have to look under the car and check the condition of ball joints and use a pry bar to determine the source of the squeak.
Here's a good video guide...
Old Nov 12, 2022 | 12:16 AM
Senecat's Avatar
1983 Nissan Shltbox
Even your car is telling you to lose some weight!
Old Nov 15, 2022 | 04:06 PM
SemperSaint's Avatar
Veteran: Marine Corps
2013 S550
My 2013 used to squeak like an old box spring. I found new aftermarket upper and lower control arms on Ebay for around 150.00 and had them put on by my local mechanic. All the squeaking went away, and the ride is so much smoother. The whole job including parts was about 700 bucks.
Old Nov 16, 2022 | 01:47 AM
Minh's Avatar
S350 2008
Check rubber bushing of front sway bar.
