Battery Question
Old Nov 15, 2022 | 01:31 PM
V12Kid's Avatar
Cl500
Battery Question
I have a 2009 and today my car wont start. The dash is dim and the starter wont turn over.
is this the front battery or the rear one? I am unsure which to change
Old Nov 15, 2022 | 06:13 PM
vettebk's Avatar
2007 S600, 2007 Chrysler 300 SRT8, 2000 C5 Corvette, 2017 Mustang GT, 2023 300C, and a 2019 Lincoln
Check the voltage on the starter battery in the front. It is used to start the car only. The rear battery is much larger and supports all the electrical needs of the car.
If your starter battery upfront does not show 12.0 volts, try a charger. It is also possible that your alternator is not putting out enough juice to keep that starter battery fresh. Once she starts, the starter battery should show a slow return to 14.0 volts or more. You might charge the starter battery fully, and then take a voltage measurement the following morning. You should still have 12.0 volts from that battery.
Please measure and report back what you find.
Old Dec 7, 2022 | 07:10 PM
Jason B's Avatar
W140 Mercedes S350, W221 S550 sport
@V12Kid - did you fix the issue? What was it?
Old Dec 7, 2022 | 07:50 PM
V12Kid's Avatar
Cl500
Ended up being the battery and the starter lol.
I was able to replace the battery myself but my local shop replaced the starter. Good to go now
Old Dec 8, 2022 | 01:56 AM
BenzV12's Avatar
W212 FL
Nice to see it was that easy to fix it
