Rear Level Sensor 2008 S550 4Matic Help!!
I think I found the tool. But, you have to remove some things first
also noting there is a flat on the ARB that makes it sit at the correct angel of dangle
the secret would be with the whole arm on the workbench - they are just idiots
I am seriously contemplating using 2 heavy duty hose clamps to hold it in place over the "clip" which I can not close. I was thinking of loosening the sway bar, not take it out, so I an move it to get to the clamp easier. You say there is a "flat spot" I did not realize this. I will be sure to find it before I "complete" this repair.
the silly clamp hardly does anything the clip is more luck than engineering - a worm-drive clamp would be many times stronger....
if you look the 14mm wide clamp (guessing about its size, about 9/16ths in foreign money) is meant to have a cushioning element to it - I guess so less shock reaches the lever senor potentiometer and hence it copes with life better. This cushioning comes from the 4 legs - a wide clamp will squash these legs, weakening the new one and stopping the shock absorption - hence you need a narrow clamp that sits between the legs (in the middle of its width)
the ARB is NOT meant to be loosened from it ends and twisted up in the bushes to get clearance - these days ARB bushes are meant to be bonded to the arm to stop noises and control roll better. If the hole arm was disconnected maybe there's a chance but aside from zero clearance in situ there must be a proprietary tool to get that silly clip closed
if you fit the clamps your way you will crack the little legs ? if you persist trying to compress the ARB the most likely output is you'll get stressed and damage the new parts
I plan on attempting to close it up with the clasp and facing me or down where I can reach it easier and see it then try to "spin" it around on the sway bar to get in place. The other alternative is to completely loosen the sway bar so I have more room but I'd rather not do that.
I don't see it breaking the "legs" as I don't intend on compressing it beyond what it would be normally.
As far as "shock" to the part I think the "ball sockets" on both ends are doing most of that. The sockets are supposed to freely move/rotate. Mine broke because the ball socket at the clip end is completely frozen with rust so that last good bump I hit broke the clip. I believe the "ball sockets" are more important as far as shock is concerned.
quite a good picture of the rear level sensor - and around top right is two of the 4 legs that crack and snap off - showing kind of - the cushioning bit that brings and the hideous clip you can't ever close
Yes, I know this is no help, but it's good to understand the culture I think. And to get Konigtiger to post the WIS document(S).
