Adding a a Agm battery in trunk
Old Nov 29, 2022 | 05:02 PM
Kevinram123's Avatar
2010 s550
Hi I got a 2010 Mercedes’ s550 4matic and I was wondering if I could add a Agm battery In the trunk for my subwoofers and mids? Is it gonna mess with any electronics or alternator or the computer or main battery? Anything helps thank you
Old Nov 30, 2022 | 01:51 AM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to W221 forum...
Old Dec 1, 2022 | 01:14 PM
BOTUS's Avatar
S500
crazy amps can pull silly current and so adding one might help - or would capacitors do it?
I'd check with after market hifi kids - the earlier cars had a monster battery in the boot behind the right rear passenger seat - find it by removing the rear most vertical trim piece in the boot... there's either one there or a massive space...
fitted by grown ups and wired sensibly shouldn't cause any issue - if you need to add silly bass / volume levels, remember you'll be deaf by 40 and or have tinnitus* (which to some is so unpleasant they commit suicide) - before the madness of modern life - just living in a town vs living in the countryside meant by age 50 u will have half the hearing level nature intended - if you EVER hear ringing in your ears after being subjected to high noise levels even fora shirt time, its a sign of permanent hearing damage
