Fixed hydrolock
a year ago stupid me drove through s storm in like 4 inches of rain and hydrolocked
most if not all would say the motor is toast
i researched
Cylinder 1 hydro locked on idle
I didn’t believe the no sayers
so we took about the ENTIRE motor to get to the cylinder rod which was BENT
So backing up
remove bolts from transmission
then mounts and front of motor
gotta cut the wiring harness
drain oul
drain coolant
then hoist motor out
put on motor stand
THEN take apart
Valve covers
oil pan
Remove alternator
remove manifold
remove square brain
REMOVE TIMING CHAIN - need specialty tools
crank case
remove bent piston
I may have missed something
REVERSE
buy new gaskets for everything
bought new starter, belt oil
solder back harness
u gotta buy the silicon glue to have it glued back as gasket to crankcase
took 3 months little by little
go to church every Sunday
then forgot about it 7 months
and
Hallelulah ITS ALIVE
now I gotta pay the god damn registration
Any questions welcomed
i Think since hydrolocked while idling the cylinder wall NOT damaged
only cylinder rod bent
spent like 5k as I was determined to fix
and I’m not doing this again
aloha from hawaii
i researched
So backing up
drain oul
drain coolant
put on motor stand
THEN take apart
Valve covers
oil pan
Remove alternator
remove manifold
remove square brain
crank case
remove bent piston
REVERSE
solder back harness
and
aloha from hawaii
Good for you, glad you fixed it.
theres was A LOT of wind and A LOT of rain was coming sideways and entered the air intake in the front grille and eventually made it into the manifold and cylinder where it locked
yes u should wait and stop IF there’s STRONG WIND
thx for asking
Any chance that you lost spark in cyl. 1 and it got cold that allowed it to flood?
Keep us posted
I must have been very lucky as down south we have down pours you cannot hardly see 50 ft ahead and I keep going as fast as possible. I used to put rainex in the windshield so I don’t need to slow down and never thought the engine could hydro lock.
Just driving behind a semi in a moderate rain creates very wet conditions for the engine and I have been in such conditions for thousands of miles. Have not had any engine issues yet.
Is this for real???
Is this for real???
