2012 Mercedes-Benz S550 (m278) Misfires Left Bank (cyl 5, 6, 7, 8)
Old Mar 6, 2023 | 05:11 PM
BOTUS's Avatar
S500
Originally Posted by cruiser02
I bought it for reliability.
Old Mar 7, 2023 | 02:21 PM
Shadly1's Avatar
2007 S550
Update: It is the infamous “motor oil in engine wiring harness” that plagues m278 engines. It has leaked enough to reach the oxygen sensors on the left bank, hence the misfire codes.
They have also stated that it has reached the ECU a little bit. They will be attempting a cleaning of all affected areas and see if that fixes it. I have a feeling neither they nor I want to replace the whole harness.
I don’t understand how an engine can be designed like this.
Get the harness extensions for the camshaft magnets. They're designed to prevent oil from travelling into your main harness. Something like $10 each.
Old Mar 7, 2023 | 04:24 PM
cruiser02's Avatar
Sounds like a great idea. Know where to source them?
Old Mar 7, 2023 | 04:27 PM
cruiser02's Avatar
Update: Car is fixed, they’ve cleaned up the harness well and changed out the 2 camshaft sensors that I didn’t.
Old Mar 7, 2023 | 05:00 PM
Shadly1's Avatar
2007 S550
Anywhere that sells the adjuster magnets will have them.
https://www.fcpeuro.com/products/mer...des-2711500156
Old Mar 7, 2023 | 07:38 PM
chassis's Avatar
2017 GLE350 4MATIC
Cost cutting and incomplete development. The testing budget and schedule was cut so the necessary tests, with sufficient length (time) were not done to discover and correct the problem with failed sensors.
MB is no different than Kia or Dodge in this regard.
Old Mar 16, 2023 | 12:43 AM
  #32
cruiser02's Avatar
Got back from a work trip and picked the car up last Monday. Drove 300 miles so far and it rides like new! I am averaging 27mpg as well
Old May 8, 2023 | 01:01 AM
  #33
cruiser02's Avatar
Have driven about 2500 miles since the sensors replacement and harness cleaning and so far so good.
Old May 8, 2023 | 09:23 AM
  #34
kevm14's Avatar
04 E55 AMG (totaled), 07 S550 4Matic, 14 E63S
Anecdotally I read a lot of issues on cars that have done a lot of sitting, or maybe short trips (basically lower than average mileage for the age). For example, my 2014 E63S with 99k had only a little oil on the cam position sensor plugs and none at the computer. Twice the mileage of yours.
Old May 30, 2024 | 11:18 PM
  #35
VarunBajaj's Avatar
2012 E550
so all that work done previously was for nothing? It was the O2 sensors!? Is the car working fine right now?
I was driving home from work yesterday when I had the engine light flash, then go solid after sometime...I limped back home but haven't driven since.
My odb 2 scanner says cylinders 5,6,7 misfiring. Guess it could be the same. Was wondering if I should take it to Robinsons in toronto or to the dealership!!?
How much did it cost you?
Old May 31, 2024 | 03:57 AM
  #36
BOTUS's Avatar
S500
thats three posts going round now on funny idle and strange misfires on the V8s - this link to the same engine in another part of this forum shows an owner going through major huddles trying to resolve
https://mbworld.org/forums/cl55-amg-...8-low-rpm.html
as it was some special dealer tool magic that resolved - makes me wonder with the point here about not using it much !
about 4 years back on later cars it turned out some extra software in the engine ECU needed to be removed... if the car sat greater than 3 week of no use, a mistake in the engine management software incorrectly interpreted data from the ambient temperature sensor and threw a fake EML (why does it even look at it - other than it was how the dieselgate emission scandal on the merc tractors functioned !!! ) these cars get fixed by flashing an update at the engine ECU....
and why am I mentioning it - my car just before the fuel consumption fell off a cliff, dropping 30% at low speed for the last 18 months threw an ambient temp fault just before that happened - it was counting down as as I drove - did it twice, then the outside temp readings have worked correctly ever since - but fuel use is horrific - I can't find a cause or any faults (FYI mates CL did EXACTLY the same thing about the same time !!!)
Old Jun 1, 2024 | 12:37 AM
  #37
cruiser02's Avatar
Wouldn't say it's for nothing because I got new parts out of it (ex. coils and plugs). But yes, they weren't needed at the time. Car has been great since with zero problems, and I have put on about 20,000 miles since.
The issue is that the oil in the harness can ruin all sorts of things, in my case it was the O2 sensors. Cost was about $1500, new sensors, harness cleaning. I would NOT take it to the dealership, they are the ones that swore up and down that it is the coils and plugs. You need a mercedes only performance shop, preferably one that has knowledge in M278 engines. Most shops would say you need a new harness to the tune of $10,000+. The owner of my shop is super knowledgeable and has engineered a way to clean them instead of replacing.
Also look into the purchasing the pigtails that connect to the camshaft sensors, I have linked them in previous posts.
Old Nov 6, 2024 | 08:35 PM
  #38
MercBenz22's Avatar
I have a 2012 W221 as well. My car has been jerking a lot lately when I tried to throttle faster. Today, it jerked a whole bunch and then flashed the check engine light. I turned the car off and started it about 5 minutes later and the light was gone. It seemed fine until about couple minutes into driving, did the same where I throttle harder and light came back. I checked the code and it seems to be:
P030185 - Combustion misfiring of cylinder 1 has been detected. There is a signal above the permissible limit value.
Р030085 - Combustion misfiring has been detected. There is a signal above the permissible limit value
P06AF00 - The torque control system has triggered torque limitation or shutoff of the combustion engine
Before I go replacing parts, would this be a similar issue to what you experienced? Could there possibly be oil in the harness / cam shaft sensor? Would you be able to guide me on where this harness is so that I can inspect it? Any videos on it? Any help will greatly be appreciated!
Old Nov 12, 2024 | 01:03 AM
  #39
cruiser02's Avatar
Yep, sounds similar to my problem. Could be a multitude of failure points, from ECU to O2 sensors, and many more in between (whatever the engine harness connects to). Look up M278 camshaft position sensors and go from there, fairly easy to check and replace.
Old Jan 17, 2026 | 12:44 AM
  #40
johnathan1's Avatar
2001 ML320, 1998 E430
I just wanted to add my experience with my 2012 CLS550. Misfiring after warming up, Bank 2, mainly cylinder #5, but also 6, 7 and 8. Computer keeps going in and out of closed loop, runs smooth in open loop, switches to close the loop, starts, misfiring, kicks out of close loop back in the open move and run smoother again. Over and over. Bank 2 lean codes as well. The problem with her being the O2 sensors, replaced all 4 of them, problem solved!
