2007 S550 Japan COMMAND error
WHen I turn the car on the screen starts green then it has a loading screen kind of like it's trying to do an update and then finally comes up with an error in Japanese.
using Google Translate it seems like it's trying to update the Map software even though there is no disc in any of the changers.
if I pull the hard drive then it will load with a green screen and eventually come up with system error.
I do have a Chinese DAS Star computer which cannot connect to the command system when it's showing this error.
every once in a while it will start as normal and I can connect to it fine but can't adjust anything in the navigation.
any thoughts for ideas that may point me in the right direction?
https://mbworld.org/forums/mercedes-...rks-fixed.html
If the car sits a while (I have 7 cars) then the command will turn on fine but with out the map (says loading)
Then the next start is green screen and loading error again.
Can the map software be reinstalled somehow?
pulling the hard drive is very very easy
