2010 S550 woes
So I am attempting to repair as much as I can my broken S550. Here is the backstory… about a month ago it was in an accident. Right front corner took a hit. The bumper, fender, headlight, and hood were toast. Also the coolant reservoir took a hit as well. After the accident my left rear air shock sagged all the way to ground. Ok now fast forward a bit and I started working on repairing her. I managed to get the fender and bumper off and I replaced the coolant reservoir with a used one I picked up online. So far so good. I thought the valve block might have been affected so I replaced that too with a used one. The rear suspension still did not want to raise up. So then I started looking for leaks in the hoses. That is when I found the culprit, a completely severed air line. Here is where things went wrong. It was wrapped up with a ton of wires with it, when I pulled back the electrical tape I not only exposed the broken line I also found an exposed wire. It’s not severed, but it is exposed. I must have touched it because now my car won’t start. The dash lit up like a Christmas tree, all kinds of errors were popping off. I left it for a day and when I came back it was completely dead. I tried jump starting the car and I was able to get the electronics back online but she won’t crank at all. Just clicks with the dash flickering as I crank. The scan tool is filled with error codes, tons of low voltage errors. Obd2 scan shows two codes, p0116 and p0607 codes. I cleared all codes and I tried jumping it again, this time letting the battery charge for a long time. But as soon as I disconnect the jumper cables the voltage goes from 12-13v down to about 4v and nothing works again. Battery is only a year old and alternator was replaced not even 9 months ago.
Any ideas what could be the issue?
get a fully charged battery - put support on it - before trying to play, get all light inside and out off, get all the HVAC fans off.... scan then wipe all the garbage codes
now where is it ?
now where is it ?
I don't even try to do a diagnosis scan without the heater fans off, and at least a battery charger on the rear to give it a chance...
if trying to break it with an update I have a 40 amp power supply... the latest cars (some JLR stuff) need 120 amp battery support !!!!!
