Trunk won't open with key and buttons
Old Jun 29, 2023 | 12:21 AM
Lee Wei's Avatar
S550
Hello there everyone,
My 2011 S550's trunk will not open today with the key fob and the buttons (front by the door, or the 2 in the trunk lid).
Using the key manually works fine.
I hunt around for the fuse and found a reference to fuse 74 (by dash) but it seems to be good.
I simply exchange that one with another 30A to test.
Any other ideas on what else I can try?
Old Jun 29, 2023 | 12:30 AM
Shadly1's Avatar
2007 S550
Could be a bad trunk release module. You should scan the car to be sure. Those things are too expensive to take a guess at.
Old Jun 29, 2023 | 12:54 AM
Lee Wei's Avatar
S550
Thanks @Shadly1 , sounds like this might show up in a scan. Good to know.
My wife is bringing my scanner from another house back here tomorrow, so I will scan it to see what code I get.
Old Jun 29, 2023 | 01:34 AM
Lee Wei's Avatar
S550
From what I read, even if I replace the control module, it has to be reprogrammed with my VIN#?
Sigh - meaning I wouldn't know how to do that.
Old Jun 29, 2023 | 09:58 PM
MBCO's Avatar
2015 SL550 & 2012 S550 4matic
This is where MB star Xentry DAS is the best scan tool use, as it can diagnose at a deep level, is this what you will be using? Other tools may work too. Good luck and keep us posted
Old Jun 29, 2023 | 11:28 PM
Lee Wei's Avatar
S550
I had a strange experience with this one today.
Firstly, I have the Autel OBDII tool, which did not pick up any error codes.
(Newbie on these tools, so I might not be doing the correct thing to begin with).
In any case, I opened the trunk manually with the key today, and suddenly everything is working fine.
It turns out that depending on how the key is flipped in the lock by 90 degrees, it will turn off the electronics.
I have no idea how the lock was moved to the "locked" position in the first place.
Now I can reproduce the work/not-work scenario by simply turning in the key in the lock.
Old Jun 30, 2023 | 08:38 AM
kevm14's Avatar
04 E55 AMG (totaled), 07 S550 4Matic, 14 E63S
That sounds like a valet feature that is probably in the owner's manual.
Old Jun 30, 2023 | 12:56 PM
Shadly1's Avatar
2007 S550
That's interesting. I've never tried the valet mode. Too poor for valet parking. LOL
