Static crackle, Sound System HELP Needed!
Old Jun 30, 2023 | 01:15 PM
S Khalid's Avatar
2002 c320 wagon
Just got a 2008 S550 With Harmon Kardon sound system. I hear a bit of weird very low volume crackling in sound system, more like static clicks, not sure what it could be and happens on ALL audio sources. Also, when this static noise happens, the mouse the COMAND wheel function is erratic when trying to control Audio portion, the selection keeps jumping from one to another, and i cant even change basic functions such as air conditioning which is annoying.
Any clues where i should start? Is it an amplifier issue?
Old Jul 1, 2023 | 07:36 AM
nath_h's Avatar
2008 CL550, 2022 EQB 300, 2023 EQS 450 4Matic
There are other people here who know way more about this than I do, but you need to start by getting either a Xentry setup, or at least a decent code reader like the Foxwell 510 Elite. You can look for obvious problems, instead of giving the dealer an open checkbook to look for issues. Try isolating each speaker in the settings....is it every speaker, or just one in particular? The Command wheel function sounds like a separate issue. There are plentiful used parts on Ebay if you find a component fault like a speaker or amplifier.
Old Jul 1, 2023 | 07:43 AM
S Khalid's Avatar
2002 c320 wagon
It's all speakers, and based on what I've read online, when this problem occurs, the command wheel stops functioning correctly, if anyone has faced similar issues please share findings
